Eibach pro-kit and Tokico blues
After changing the stock suspension to Eibach pro-kit and Tokico blues along with 17" Alessio wheels with 245-45 Goodyear Ducaro F1 tires (28 PSI front and 26 PSI rear) and a Courtesy FSTB, I noticed tremendous improvement in handling and looks and would never return to stock. My only gripe is the relative harshness of the ride.
My question to you guys is whether there is a definite advantage (and improvement) in ride quality if I change to H&R springs. From what I read on the forums the ride quality is softer than Eibachs. Is it worth spending the extra cash for the H&R's??
Uromax95
Uromax95
I went from stock SE to H&R and Toks. Nice upgrade. Better than stock not too harsh at all.
Also, keep in mind, the Toks are quite sensitive, if you lower your car to 2" or more, those Toks are history. If you keep with the 1.3-1.4" drop of the H&Rs, you're good to go.
DW
DW
I agree with Str8ridin. I have sprints and tokicos, it's harsh but it corners really well. I also like the look of the bigger drop. Maybe if I decide to grow up some day I'll switch to H&R's, but until then I'll stick with the sprints.
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Originally posted by MaximaRacer
I have Tokicos and H&R. Ride quality is not that bad.
Originally posted by Uromax95
I'd love to take your max for a spin and see if there is a difference between the Eibachs and H&R's. I'll stick with what I have for now. Anyway somebody says ride quality is for girls..!!
I just recently switched from Eibach to H&R (Tokico struts). The ride quality is much better, and the cornering loss is minimal. It feels like the cornering is more controlled with H&R. With the Eibachs, my car would sometimes bounce over a dip/bump in the middle of a corner, but the H&R's don't bounce as much. Just my 2 cents.
What to do! That is the question. Your opinion regarding the better ride quality is important and will probably make me spend the cash before the year is over.
tarun900
19
12-20-2021 06:57 PM
MaxLvr21
10-17-2015 12:11 PM
Stagnet04
10-11-2015 08:16 PM
