Will 20" fix
Re: Will 20" fix
Originally posted by bobbymc82
I want to put 20" on my maxima i have 18 right now and there is no rubbing i want to know if i can put 20" on what size tries i would need and how much it would rub.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
I'd recommend against it. They are typically very heavy and will slow down your car. Plus they require very small sidewalls which will make your car ride very rough. Tires will be spendy. Also I don't know how your roads are but I'd bend these in a heartbeat.
As for size? 245/25 20's or 235/30 20's would be better.
I don't know about the rubbing. Search is the right answer.
Re: Re: Will 20" fix
Originally posted by HondaKiller718
20" do fit with no rub, do a search there is one max on the board with rims bigger than 20" and he did post a pic.
SuDZ
20 inch rims make make your ride really rough, if your going to get 20's......make sure they strong cause its gonna feel like your riding on rim instead of rubber......potholes will screw em up, i'm guessing that you'll prolly need like a 235/30 tire
SuDZ
nah, the ride with my 20's is better than when I had 18's actually.
Your goal is to get the overall diameter of the tire to match the stock size tire. From there it is simple math.
Stock tire size
215/55 16 = 25.3" diameter - goal size
235/30 20 = 25.6" diameter - best size
245/25 20 = 24.8" diameter - tire's .8" too small
245/30 20 = 25.8" diameter - tires .5" too tall
245/35 20 = 26.8" diameter - tire's 1.5"! too tall
Stock tire size
I've never seen some of those tire sizes before, there's really a 25 series tire for 20" rims?
Stock tire size
Stock tire size
Ouch $275 per tire! I didn't even pay that much for my rims plus tires!
