Door Column Tape Removed & Sunroof Visor Installed...
Old Feb 21, 2002 | 11:39 PM
ebmorgan's Avatar
Door Column Tape Removed & Sunroof Visor Installed...PICS!!!
What do you guys think?
Old Feb 21, 2002 | 11:51 PM
Prolepsis's Avatar
Re: Door Column Tape Removed & Sunroof Visor Installed...
That white stripe is tight against your dark tint. That black part is just tape? How did you get it off?
Old Feb 22, 2002 | 01:05 AM
ebmorgan's Avatar
Re: Re: Door Column Tape Removed & Sunroof Visor Installed...
Yup...just tape... It's the same tape they use for pin-striping on a car. And the best part is that it's the full finish underneith...clear coat and everything.
It's really simple to remove...
Get a metal ruler and a utility knife or razor blade...something to the effect. Use the ruler as a guide and cut the tape at the door seals. Then take a hair dryer on HOT and start warming up the tape at the top. Then just start peeling. Heat the tape as you peel down. If you get it good and warm, the tape will come off in one big piece and won't leave any glue residue behind. If you get some glue left...use GOO GONE to take it off. Then when the tape is off and the finish is clean, polish then wax then buff.....done. Only takes about an hour...hour and a half.
Old Feb 22, 2002 | 12:56 PM
ebmorgan's Avatar
bump....
Old Feb 22, 2002 | 01:51 PM
BlancMax's Avatar
Was that area brighter (less faded)? Also, could you take a close up picture? I have a 96 pebble beige and I'm worried about it looking funny on my car. BTW, it does look very good.
Old Feb 23, 2002 | 03:59 PM
ebmorgan's Avatar
I'll try to get some close up pics up here tomorrow. As for the condition of the paint underneith....there was absolutly no fading. It has clear coat and everything. I matches the rest of the car perfectly. I can't gaurantee, but I'm pretty confident that the paint is fine aon any Max/I30 with this tape.
Old Feb 25, 2002 | 12:34 PM
ebmorgan's Avatar
Here are some close-ups...and as you can see in the last pic....the paint quality is sooo good that you can see a reflection of me taking the picture...
Old Feb 25, 2002 | 02:30 PM
iansw's Avatar
I think, eb, what they are worried about is the fact that since 4th Gens are a few years old, they have had some amount of oxidation.
They are worried about the paint not being faded enough to match the rest of their car's paint, which has oxidized a little over the years.
Since your car is white, and fading on white is minimal (hence the term: Resale White), you probably see no difference.
On a maroon, blue, or black max, for instance, there may be a considerable difference (depending on the amount of fading) between the pillars which look brand new and the rest of the car, which may be faded.
IanS
Old Feb 25, 2002 | 04:33 PM
ebmorgan's Avatar
Possible...but I doubt it.
Old Feb 25, 2002 | 04:36 PM
mzmtg's Avatar
Minister of Silly Walks
My car is Granite Pearl. The paint under the tape was not noticably newer looking...
Old Feb 25, 2002 | 04:37 PM
iansw's Avatar
BlancMax said:
"Was that area brighter (less faded)? Also, could you take a close up picture? I have a 96 pebble beige and I'm worried about it looking funny on my car. BTW, it does look very good. "
So what did you mean, BlancMax?
Old Feb 25, 2002 | 06:36 PM
Tactics's Avatar
It kinda remotely looks like a crown victorian.
Old Feb 25, 2002 | 07:12 PM
SLC I30t's Avatar
Ok I was liking what it looked like till that comment was made. I'll think about it when my tape begins to fade. It hasn't yet. So I'll keep with the stock tape look. Maybe its the rims? I dunno, but I have a white I30 and Well...no way. I have to keep looking like the anti-authority figure I am.
Old Feb 26, 2002 | 03:57 PM
ebmorgan's Avatar
It does kind of, doesn't it?.... That's okay...It'll look TOTALLY different after KYB AGXs, Sprints and a Impal A32S Body Kit....
jsmith24
Feb 1, 2016 12:35 AM
ef9
Sep 29, 2015 11:29 PM
Junebug1701
Sep 25, 2015 01:54 PM
ef9
Sep 5, 2015 11:18 PM
