I could barely hear my alarm
Feb 22, 2002 | 08:27 AM
Is there any way I could make my alarm sound louder when I unlock and lock the car?????
Feb 22, 2002 | 09:08 AM
Re: I could barely hear my alarm
Quote:
I thought our alarms don't sound. You only hear a click click.
Feb 22, 2002 | 09:25 AM
Re: Re: I could barely hear my alarm
Quote:
same here
If it's a newer alarm by DEI (Viper, Python etc)... The siren has a small black wire loop. Cut it and the arm/disarm chirp will be louder.
Feb 22, 2002 | 10:18 AM
how can i test my factory alarm?
its flashing
Feb 22, 2002 | 11:06 AM
Quote:
its flashing
??? Assuming factory alarm... arm the alarm then wait until security LED begins to flash... open door thru open window window
For Mamoru's question... assuming aftermarket alarm
Feb 22, 2002 | 04:29 PM
let's clear this up a bit
i think he's talking about the same problem i'm having. my alarm doesn't chirp when i lock and unlock. how do i fix this? is it just a wire or something ? one time i was under the hood looking for a place to run a wire and when i was done, for the next two days it worked then stopped the next time i went under the hood. what's goin on ?
Feb 22, 2002 | 06:18 PM
Re: let's clear this up a bit
Quote:
The alarm isn't supposed to chirp when you lock and unlock. It's just not something the 4th gens do.
Feb 22, 2002 | 06:42 PM
A few days ago I did an experiment with the truck relay that clicks twice when doors are locked with remote. In order not to screw up something, I used another relay being drived by the trunk relay, and then run the added relay to one of the front horns. Didn't sound nice like some cars designed for that chirp, plus it was too loud(can be solved with a resistor in series to drop some voltage). I'd like to find a device that sounds similar to those nice cars' chirp, and install it in the trunk so I don't have to run wires through firewall.
Feb 23, 2002 | 01:54 PM
Re: Re: let's clear this up a bit
Quote:
that's just what i thought !! but then i heard it and it made jump from the sound of it. i kept locking and unlocking it to make sure it was my car and it was. my alarm was DEFENITELY making that chirp chirp sound. i don't know about yours, but under my hood there's a lil black horn in the far rear right corner. check yours.
Feb 23, 2002 | 03:41 PM
I just make my own chirping noises.
<lock> chirp
<unlock> chirp chirp
The neighbors always look at me funny though
Feb 23, 2002 | 04:30 PM
Re: Re: Re: let's clear this up a bit
Quote:
<lock> chirp
Feb 23, 2002 | 05:00 PM
Its probably worth it to mention that with the factory alarm, the rear doors are not wired.
Feb 23, 2002 | 06:00 PM
<lock> chirp
You do that to?????????????
