Qs about Stillen Front lip....
Old Feb 28, 2002 | 10:35 AM
MAXTOUT's Avatar
How much of the stock bumper does the lip cover? I am curious because I have a pretty mean scrape at the very bottom of my front bumper on the pass. side. I was thinking maybe a stillen lip would cover it.
Ted
Old Feb 28, 2002 | 10:56 AM
BlkCat
The lip covers the whole bottom part of the lower valance. If you look below the bumper you see the lower intake. The spoiler sits on top of the lower part, covering it and it wraps around as well, hiding the stock chin.
The spoiler is held on by double sided tape and rivets. If your car is already lowered then you'll have to adapt to a different way of driving in and out of parking lot ramps as well as the odd speed bump.
Old Feb 28, 2002 | 11:16 AM
ny96max's Avatar
look for pics!
Old Feb 28, 2002 | 12:25 PM
BlkCat
Here's a so-so frontal shot of my Max with the lip:
http://imagem.webphotos.iwon.com/100...M0.1616785.jpg
Old Feb 28, 2002 | 02:20 PM
JDM4LIFE's Avatar
that grill's pretty sweet, you modify that yourself?
Old Feb 28, 2002 | 03:43 PM
MAXTOUT's Avatar
Thanks BlkCat, that pic has answered my question.
I agree with JDM, your grill looks nice. If you don't mind, how did you do it? Is it gutter mesh from HD?
Ted
Old Feb 28, 2002 | 03:49 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Check sig bro
Old Feb 28, 2002 | 05:02 PM
justmax's Avatar
I see one of you guys has a 95-96 and one has a 97-99 front fascia... was there any modification needed to make the lip fit on either car?
Thanks,
Justin
Old Feb 28, 2002 | 05:31 PM
sil SE's Avatar
install
on the install for 97+ did you put screws thru the central part of the bumper? how did you do that? jus screw thru it? what kinda screw /rivets do i use
Old Feb 28, 2002 | 09:32 PM
WizzaMax's Avatar
Thanks,
Justin
Also interested in the response to this one...I cannot figure where the measurements are off and require a diff style front spoiler.
Old Feb 28, 2002 | 11:16 PM
BlkCat
Ted
Yep it is...Do a search for my thread "How I Made my Custom Grille"...I explain how...
Old Feb 28, 2002 | 11:53 PM
justmax's Avatar
Hey Wizza, I just checked Stillen's website, and there are 2 different parts, one for 95-96, different one for 97-99.
FYI
Old Mar 1, 2002 | 03:12 PM
sil SE's Avatar
hey blkcat , anyone with the lip on. i have a question about the top of the ends of the lip, on the car the fender flares a bit around the wheel well, does the lip fit tight over this? im tryin to test fit and i jus noticed this
Old Mar 1, 2002 | 03:55 PM
WizzaMax's Avatar
I know they are different parts and all but not sure what characteristics on the actual bumpers are different that REQUIRE a different part...are they longer on one model than the other...? ... is one shaped that much different?
Old Mar 1, 2002 | 04:13 PM
BlkCat
The top part of the lip has grooves that allows those vertical slats in the lower intake to fit. Once it is on the lip makes the Max look like it came like that. The sides fit against the sides and theres a flap that grips the inside of the wheel well.
Old Mar 1, 2002 | 07:28 PM
sil SE's Avatar
thanks. its jus that the groove around the wheel well on the fender kinda pops out the lip but i think itll be ok. the test fitting is SUCKing and i guess i need heat or something to form fit it but im going to leave it to my body/paint guy to do it ..25-30 bucks sound not too bad? i wanted to do it but oh well its a hassle
adamgalazka
Feb 5, 2023 08:24 AM
BkGreen97
Apr 2, 2016 05:47 AM
GregL65
Sep 5, 2015 09:37 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
