My Fog Lights Just Came In
Old Feb 28, 2002 | 10:53 AM
meccanoble's Avatar
Sports Button FTW
hahaha, yes! It took almost 2 weeks cause of delivery problems but they finally came in!!! 100 dollars for full package, cheapest i have ever seen and everything is legit!!! braces, fog lights, bulbs, the traficator thingy everything!!! i'm so happy, i just gotta install these bad boys and i'm set!!! yes!!!!
Old Feb 28, 2002 | 11:11 AM
1FSTMAX's Avatar
Are these fog lights OEM? If so, how are you going to cut the holes in the bumper?
Old Feb 28, 2002 | 11:36 AM
meccanoble's Avatar
Sports Button FTW
i got a box cutter...i just cut the holes in my mask, they got good instructions, use masking tape so u don't scratch outer surface and stuff...my problem is:
Instructions say that wiring is made so i can't use fog lights when using high beam, they automatically shut off...is there a way to wire it so they are ALWAYS on when low beams and high beams are on?
I did a search wit "installing fog lights" and got nothing of that sort...just info on right pieces to get...i'm going to start installing and maybe after 10 min, i'll come back to see if any of u have a way to solve this...if not, i'll just keep it the way stock intended it 2 be
Old Feb 28, 2002 | 11:45 AM
meccanoble's Avatar
Sports Button FTW
BIG PROBLEM!!!
OH NO, my mask is in the way!!!!! NOOOOO, i tried using the left plate and it's too big, i don't want to take off mask but i may have to
Old Feb 28, 2002 | 12:00 PM
1FSTMAX's Avatar
http://web2.iadfw.net/scutchen/max_faq/eleclight.htm
This link shows how to rewire the fog lights, to be on with your highbeams.
Old Feb 28, 2002 | 12:11 PM
njmaxseltd's Avatar
Re: BIG PROBLEM!!!
You do know Battman, once you remove your mask, everybody will know who you really are.
Old Feb 28, 2002 | 01:27 PM
Toolrocks's Avatar
PLese tell me these aren't factory fog lights. I had to order a new fog light assembly for my 95 and it was $115.00 for the housing and lens only. SOrry to hear about your mask problems. Good luck.
Old Feb 28, 2002 | 02:39 PM
meccanoble's Avatar
Sports Button FTW
yes they are factory fogs
almost done wit installation, took off mask but only part to install fogs...i'm going to put it back on but it looks better without, just dam scratches....
these are complete fog kit, the black traficator thing, the fogs, bulbs, EVERYThing for only 100 and that's including shipping...got a great deal
right now, i just put the braces in and trying to align the actual fogs and screw them in but i can't align them well cause of my big a$$ hands grrrrr
i'll keep u guys updated
going to take a look at that rewiring thing
Old Feb 28, 2002 | 02:40 PM
1FSTMAX's Avatar
post pics
Old Feb 28, 2002 | 04:00 PM
meccanoble's Avatar
Sports Button FTW
man i suck...it took me forever just to put the fog lamps in the holes! That's like the hardest part...it's too dark so i won't change the trafficator thingy (lol) tomorrow...never opened the steering wheel before so i know it's going to take a while to do...
ALSO, when looking at the instructions for making the fog lamps run even when using high beam, i opened my hood and saw two cooling things next to the fuse box...which one were; they talking about? there's one on top and there's something on right...i have no idea which one it is and i don't know where the two bolts are that i have to unscrew...can someone tell me which one and get me some picture instructions? I know i won't be able to do this wit just wording....i never changed my oil before...i think this would be a great accomplishment for me if i get all this done....last great accomplishment was the diamond cut bumpers but how easy is that?
Old Feb 28, 2002 | 04:09 PM
1FSTMAX's Avatar
http://www.5thgenmaximas.com/fogrewire.html
Hope this helps
ny96max's Avatar
i rewired my stock fogs to go on with the car off and with high beams
it was very very easy, theres one wire at the fog-relay (yellow/green) not too sure though. I jumped that to a 12volt constant and presto "rewired fogs" even using the stock switch
Ant
Old Feb 28, 2002 | 04:20 PM
meccanoble's Avatar
Sports Button FTW
ny96max, did u do exactly what those instructions said? Also, they asking for a lot of equipment...i don't have all that stuff
I don't have that black string thing
that red thing
and those three small untesils at the bottom right
all i have is that silver thing at the bottom middle
and electrical tape....would that be ok? oh and screw driver..lol
Instructions are much better but still gonna take some time for me....
OH, he doesn't say anything about working with high beams...just parking brakes
AND WHAT DOES THAT MEAN???? WHEN THEY SAY WORKS WIT PARKING BRAKES, WHEN IS THE PARKING BRAKE ON? when u pick the parking brake up? i don't understand...i see this all the time but i have no idea what it is
Old Feb 28, 2002 | 05:03 PM
syc's Avatar
syc
$100??? where did you get it. I want one.
Old Feb 28, 2002 | 05:22 PM
1FSTMAX's Avatar
I suggest to get them installed first, before you can rewire them.
Old Feb 28, 2002 | 05:47 PM
meccanoble's Avatar
Sports Button FTW
this dude named Robert. Stealth Maxima told me about him
email his secratary Susan at nissanparts@bellsouth.net
she's real cool...she actually emailed me first when she heard i needed fog lights
she says their dealership sells them cheap cause they are located in a bad place that doesn't sell much...somewhere in LA, tell her i told u about her if u actually go for it...
Also, i'll do that first...install then do the rewiring....
Old Feb 28, 2002 | 05:48 PM
iansw's Avatar
that red thing
Whoa! Chill out there, skippy.
They mean PARKING LIGHTS. parking lights are when you turn on your side lights but not your headlights.
We talked about this about a week ago over Messenger...remember? i was telling you how I use my fogs as daytime running lights because i can turn them on independant of the headlights? That's because when i installed my fogs, I did the rewire.
After the rewire, you will be able to turn your fogs on with your parking lights, headlights, and high beams.
Installing the stalk in the steering column is a piece of cake. Open the steering column, remove the two screws holding the stalk in, pull gently, undo all the harnesses, put the new stalk in, re-install screws, reinstall steering column...done.
It will be good practice for installing your Indiglos to take apart the steering column anyway.
Good luck!
IanS
Old Feb 28, 2002 | 05:49 PM
iansw's Avatar
He sold them to you for $100?!?
Robert sold them to me for $155 shipped.
And I gave him so many references on this board!
Old Feb 28, 2002 | 06:28 PM
meccanoble's Avatar
Sports Button FTW
lol, dam 155?! u must have done it a while back...but u make it sound so easy! WAit so i can make my fogs blink when my bumper lights and back lights blink wit the hazard? that's what u mean right? when u put on the hazard? Bet, how long u think it will take to open steering and put new piece in? i finish class at 5:00 got work at 6:30...if u think it will only take half hour MAX, i'll go for it tomorrow, or better yet, i'll do it between classes...lol...well, we'll see
Old Feb 28, 2002 | 06:32 PM
iansw's Avatar
I timed myself
took me 8 minutes (with a cordless screwdriver) for the steering column.
45 minutes for both foglights, 30 minutes to do the rewire.
ebmorgan actually did the rewire and the fogs. He'd done his car the week before so he was good at it.
As far as the lights, it has nothing to do with your blinkers (on the lower bumper). it has to do with your PARKING LIGHTS (other light on the lower bumper, and the lights just to the outside of the headlights)
You cannot make them flash by themselves.
IanS
Old Feb 28, 2002 | 06:39 PM
meccanoble's Avatar
Sports Button FTW
8 minutes? cool, so i give myself 2 hours..lol
from cutting the holes to putting the fog lamps in, it took me 3 hours!!
aligning them in the holes was so hard...took me a minute
so, the instructions on the first page, are those the actual instructions u used? and it took u a half hour to do that?! dam, so it's gonna take me a good minute....
Old Feb 28, 2002 | 07:21 PM
1FSTMAX's Avatar
Post pics, before and after.
Old Feb 28, 2002 | 08:12 PM
iansw's Avatar
Well, I was draining my ATF Fluid and Changing the brakes at the same time...
Sort of going inbeetween.
It hsouldn't be hard for you to do the rewire. Just follow the directions.
But the wiretap at Radio Shack that it talks about....it's important.
IanS
Old Feb 28, 2002 | 09:04 PM
meccanoble's Avatar
Sports Button FTW
i don't have a digital camera
but i'll take some pics when i got my rims and all on it.....
Old Mar 1, 2002 | 10:16 AM
meccanoble's Avatar
Sports Button FTW
too hard, need help
it's too hard just taking the screws out...lol...i don't want to take chances...anybody around my area (maplewood NJ North Jersey) that can help me with this? or any shops? all i need is someone to open my steering thing and put the new blinker switcher on the left side in...sounds easy but dam it's hard....assistance!!! please, i want to do this before my class at 2:30
Old Mar 1, 2002 | 11:33 AM
iansw's Avatar
Re: too hard, need help
No offense, mecca, but if you want to be knowledgable about your car, you should probably know how it works by taking things apart and putting them back together yourself.
It really isn't hard.
Old Mar 1, 2002 | 09:04 PM
meccanoble's Avatar
Sports Button FTW
i feel so bad...paid someone 50 dollars to do it and it only took them 15 minutes to do it...fogs are real bright, brighter than stock head lights and my diamond cut bumpers even with stock bulbs...i'm pleased at the way it looks but i feel bad paying so much....i know all of u are ashamed of me.....
Old Mar 1, 2002 | 09:53 PM
iansw's Avatar
Told ya so.
You never listen.
Did your "friend" rewire them?
Old Mar 1, 2002 | 10:28 PM
meccanoble's Avatar
Sports Button FTW
friend, that **** over priced me and that was the first time i ever met him...no he didn't...i'm going to try and do THAT myself, instructions u gave me are real good...if i get real worried, i'll go to this maxima installation spot a half a city away from me...trying to locate them so i can have them do my head unit installation (kenwood DPX 4020)....adapters and stuffa re going to kill me....
Old Mar 2, 2002 | 12:14 AM
NYCe MaXiMa's Avatar
Wow, I wish I saw this thread before I got my fog lights, I paid 175$ shipped I believe. All hardware included, new turn signal stalk and all. Took me around 40 minutes to an hour to put them in with my dad helping me out a little bit, it's very simple, and straight forward. BTW, Ian, your car is freaking tight looking, the more i look at that sig pic, the more I regret passing up a white 97 GXE with a sunroof and grey interior which sold right before I bought my car for about 500$ then I wanted to spend.
Old Mar 2, 2002 | 01:15 AM
iansw's Avatar
Heh....Thank the sunny day in Seattle and the great pics by ebmorgan. (he owns an I30, and is on this board).
Seriously...Thanks! I've put alot of love into her. It's nice to be noticed.
Coming this weekend: Painted Calipers! <woot!>
Body Kit by end of summer, I hope...If Shadow finishes it <hint>
IanS
Old Mar 9, 2002 | 04:45 PM
Rutnick's Avatar
Re: My Fog Lights Just Came In
why type of delivery problems?
Old Mar 15, 2002 | 02:29 PM
jhlee_99's Avatar
meccanoble,
i'm about to place my order with susan. their asking for a postal money order. is this normal? is this how you paid for it also? please let me know. thx.
jhlee
Old Mar 15, 2002 | 10:58 PM
Rutnick's Avatar
Re: Re: My Fog Lights Just Came In
Originally posted by jhlee_99
meccanoble,
jhlee
I just got my fogs and sent a postal MO. It worked out fine. Wouldn't you know that it has been raining since I got them. I at least got the TS switch installed and hoping for good weather this weekend. I asked for and got a UPS tracking # and got the fogs in 2 days.
Old Mar 16, 2002 | 08:25 AM
JeepRage's Avatar
do the stereo yourself.. its not worth paying a penny to get it done... it should be easier than the fogs... but that did have difficulty, so maybe not..
Old Mar 17, 2002 | 01:46 PM
jhlee_99's Avatar
Re: Re: Re: My Fog Lights Just Came In
thanks! that's what i needed to hear!
jhlee
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
