Help! My car won't start
Old Mar 3, 2002 | 11:51 AM
nanukumari's Avatar
i need help with my car...it won't start. all the lights work, but it struggles to start before cutting off. if i try more than a few times, it won't even try to start, no noise, nothing. the car has gas. for the last week, its been struggling to start, but it always kicked over, now it won't...i don't know much about cars, but maybe its the starter or fuelpump...how much does it cost to fix those?...thanks in advance for any help.
~Nanu
Old Mar 3, 2002 | 11:53 AM
Vyrus's Avatar
Is it a '95?...
If so it may be the starter.
-Cyrus
Old Mar 3, 2002 | 12:31 PM
GreenMaxVE's Avatar
Re: Is it a '95?...
Probably the battery. Check the battery w/ an ohmmeter. Lights don't take that much power to operate, but a starter does. The starter may not turn, but the lights still work.
Old Mar 3, 2002 | 12:47 PM
nanukumari's Avatar
Re: Re: Is it a '95?...
yes it is a 95? whats an ohmmeter? thanks in advance
Old Mar 3, 2002 | 01:02 PM
GreenMaxVE's Avatar
Re: Re: Re: Is it a '95?...
It's a little electrical tester that measures voltage, resistance, ect. If you don't have one take your battery to autozone, I think they will test it for free. Or jump start your car from someone else's car, this will rule out a bad starter.
Old Mar 3, 2002 | 03:02 PM
MaximaRacer's Avatar
also check all the fuses
Old Mar 3, 2002 | 05:11 PM
SonicDust187's Avatar
I had the same problem on my Camry. I changed the battery and everything worked perfectly.
Old Mar 3, 2002 | 05:40 PM
Finality's Avatar
It might be the alternator. I took a long long screw driver reached down there and gently tapped the hammer as she started it up. Worked fine after that.
Old Mar 3, 2002 | 05:43 PM
Old Mar 4, 2002 | 06:35 AM
blkmax97se's Avatar
I had what sounds to be the same exact problem with my '97. It was rather damp here in Chicago on Saturday so I think that may of had something to do with it. I don't think it has anything to do with the starter since it would start for one second and then shut down. As if it didn't have gas. (I did have a 1/2 tank).
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
