Antenna Help
Old Mar 3, 2002 | 05:01 PM
gustiferjones
Antenna Help
I need to replace my sisters antenna in her 96 maxima becuase she decided to take it through the carwash up (again....).
I've never really worked on a car before (aside from my firneds kitcar he's building - fierro ferarri), but I am getitng the Haynes manual for the car, so I figure that's a good palce to start.
I'm looking to put a permannantly upright antenna in. Is this possible? What can be done in order to stop the motor for the antenna from trying to put it up?
any help would be much appreciated!
Thanks in advance!
-Arieh
Old Mar 3, 2002 | 06:13 PM
StygianMax's Avatar
Re: Antenna Help
Thanks in advance!
-Arieh
I had a similar problem w/ my '87 Legend Coupe when the antenna motor died. I wasn't about to pay Cdn$300+ for a new one! B/C the radio reception was still ok w/o the antenna being wired to the receiver, I just disconnected the 3-wire harness. You should be able to do the same though with the Max's antenna pushed completely in. No power= no antenna extension.
Sorry, no experience in installing a permanent antenna.
Old Mar 3, 2002 | 08:50 PM
dch95's Avatar
Re: Antenna Help
Thanks in advance!
-Arieh
It is possible to install the fixed antenna. The hardest part will be finding one that fits the contour of your rear fender. The power antenna will be removed from the car to allow you to install the replacemaent so you wont have to worry about the motor. The motor is part of the antenna. I,m surprised though that you don,t just replace the antenna mast rather than the whole thing.
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
