Oxygen Sensor question
Old Mar 10, 2002 | 07:03 AM
MaxMax's Avatar
Hi,
I recently replaced an oxygen sensor on my 99 maxima, but the check engine light keeps tripping with the same code. 0901 right heated oxygen sensor bank 1,3,5.
Where is this sensor exactly? Standing in front of the car, I see one with the wires, and another set of wires going towards underneath the car. And I see another one when I took off the front passager side wheel. Which one is the sensor for bank 1,3,5.
Also do all three sensors use the same part? or are they different for each one. so the rear ones can not be used for the fronts one and so forth?
Thanks in advance.
Old Mar 10, 2002 | 07:11 AM
VQdriver's Avatar
Re: Oxygen Sensor question
Originally posted by MaxMax
Hi,
Thanks in advance.
did you reset your ecu? did you replace all of the O2 sensors?
Old Mar 10, 2002 | 07:17 AM
MaxMax's Avatar
A local mechanic replaced 2 oxygen sensors, but the same code is still tripping. I've reset the ecu myself a few times now, and still the same code. So I was thinking he may have replaced the wrong one!! So the problem was never fixed. So I want to get all the info before I go talk with him.
The oxygen sensor that he did not replaced is the one I can see inside the front passenger wheel well. Could this one be the one for bank 1,3,5?
Old Mar 10, 2002 | 09:09 AM
Eric L.'s Avatar
I believe left bank is the "front" of the engine, and right bank is the "back" of the engine (looking towards the engine standing in front of the car).
So yes, the right bank O2 sensor is the one you see with the passenger front wheel removed.
Old Mar 10, 2002 | 09:30 AM
VQdriver's Avatar
Re: Re: Oxygen Sensor question
if i remember correctly, there's one O2 sensor at the front of the ypipe, one at the exiting end of the ypipe, and one around the main catylist. it wouldn't hurt to have them all brand new at this time.
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
