fuel pressure regulator
Re: fuel pressure regulator
Your car could stall when you floor it. To really know for sure, put a test gauge on it and get some readings.
Originally posted by ftb87
How can you tell if one goes out?
The pressure should be 34 at idle and 43 WOT. To check WOT "A few seconds after ignition switch is turned OFF to ON pressure should read approx 43 psi" from the FSM. Sounds like you are pretty close though. My old car had a weak fuel pump though and it was difficult to start unless you turned it off and back on again then it started fine. Not much help but thats all I know.
Good luck in tracking it down.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
