Stall Problem
Old Mar 14, 2002 | 10:19 AM
Stall Problem
I have a problem where my '98 SE stalls, or I should I say, never really starts. It only happened a couple of times when it was cold. You turn the key, the engine turns and starts but it immediately stalls out. The dealer said that it could be becasue the fuel tank was low or maybe the injectors need cleaning.
I had a '93 chevy for 8 years and never once did I have the injectors cleaned and never had such a problem even with next to no gas.
Anyone experience this problem?
Thanks!
Old Mar 14, 2002 | 12:25 PM
NotNew!!NewSN!!'s Avatar
Re: Stall Problem
Thanks!
when was ur throttle body cleaned last, next ur idle air control valve is bad(it wont idle higher like it should in the cold so it just stalls) if it even idles at all, next tps sensor. only 3 i can think of that affect that cuz it happend to me
Old Mar 14, 2002 | 12:45 PM
njmaxseltd's Avatar
Start by cleaning your throttle body. Go here for more info and pictures. www.motorvate.ca Only cost you about 5 bucks for the can of cleaner.
Old Mar 14, 2002 | 05:42 PM
ny96max's Avatar
honestly the throttle body wont effect this. I cleaned my throttle body and she still stalls out too when its really cold out. But once i drive it around for the day it wont happen again.
I think i has to do with the fuel system or maybe a bad sensor somehwere. I know my kock sensor is shot so im gonna try that and see what happens.
Ant
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
