impact wrench power..
Old Mar 27, 2002 | 06:53 AM
itsgt's Avatar
For tires...all i need is about 85 ft/lbs to tighten it right?
so if i get a impact wrench which delivers up to 350 ft/lb...will that be a better investment then buying a manual torque wrench for basically same price which delivers upto 200 ft/lb?
thanks
Old Mar 27, 2002 | 06:57 AM
1MAX2NV's Avatar
Re: impact wrench power..
Impact wrench setting is not as accurate. Impact wrench has a hammering action while it turns. It great for breaking a nut/bolt loose, but not so great for tightening to spec.
thanks
Old Mar 27, 2002 | 07:34 AM
kushane's Avatar
Beware
Stay Away! Stay Away! Using an impact wrench is probably the easiest way to end up with warped rotors. I took my old Mazda to Brake Check to get the pads replaced. When I picked it up - every time I touched the brake pedal - the darn front would vibrate like crazy. Brake Check denied any wrong doing and I didn't know any better. Later the dealer diagnosed it as warped rotors possibly by using an impact wrench. Since then I make sure that any service shop that works on my cars only use an impact wrench to remove the wheel.
When a manufacturer recommends a torque setting for a bolt - I'd stick to it.
Old Mar 27, 2002 | 07:47 AM
itsgt's Avatar
Re: Beware
well that's what im talking about, impact wrench just for removing the wheel.....nothing else.
Hdnseek
Sep 9, 2015 05:55 AM
JMag90
Aug 25, 2015 09:17 AM
NissLover
Aug 22, 2015 10:26 AM
sleeper
Mar 26, 2001 06:57 PM
Kevin Wong
Jan 22, 2001 02:37 PM
