PR CAI Instalation
Old Mar 28, 2002 | 06:08 AM
MadMax55's Avatar
PR CAI Instalation
My PR CAI should be arriving very soon . It' my first performance mod and I was reading the instalation directions from custommaxima.com and it doesn't seem that hard to do. I have a 98 GLE and I have never done a mechanical upgrade to my car. Is it easy enough for a first timer to do? Also when its done would it be normal for a check engine light or something to go on?
Old Mar 28, 2002 | 06:10 AM
Vic's Avatar
Vic
Re: PR CAI Instalation
Check engine light should not come on if you connect everything back correctly. I'm sure your going to remove the battery when drilling/installing so it'll reset.
Vic
Old Mar 28, 2002 | 06:23 AM
BRIGBOY's Avatar
If your over 100,000 miles,
,its safe to say your O2 sensors will be burned out in a month or so so start saving for them...
The hardest part is removing the stock intake, which is actually really easy, just start unscrewing everything..
Old Mar 28, 2002 | 08:25 AM
JAIMECBR900's Avatar
Also make sure you line up the template correctly otherwise the new intake will look crooked. Take your time and block out a couple of hours at least to do it. It's not very hard to do, as long as you have the right tools. The hardest part is cutting out the hole on the fender. Make sure you put either the gasket that comes in the kit or something around the edge of the cut out to keep from scrapping noises from the CAI later. Make sure to mount the temp. sensor as specified on the directions and you will have no problems. As stated, you will have to take the battery out all together so, CEL issues shouldn't be a problem, but don't be surprised if you get O2 sensor codes shortly after, as stated in a previous thread. Finally, don't be scared when you hammer down the first time and you hear a loud growl from under your hood, it's just your new CAI saying Howdy!!!
Old Mar 28, 2002 | 10:39 AM
MadMax55's Avatar
THANKS
THANKS FOR ALL THE INPUT. MY CAR HAS 24,600 MILES ON IT WILL THIS MEAN THE O2 SENSORS WILL LAST LONGER OR SHOULD I STILL EXPECT A PROBLEM FROM THEM. THANKS AGAIN I'M FEELING MORE CONFIDENT TO DO IT MYSELF.
Old Mar 28, 2002 | 10:46 AM
Soon2BMaxed's Avatar
Re: THANKS
no, i have 110 grand on the clock and ive never had a problem with my O2 sensors just take your time and do it right. putting the pedal to the floor is going to become an addiction after this i hope you know.....
Trevor
Old Mar 28, 2002 | 10:48 AM
marcel's Avatar
I used (brought) a 21/4" hole saw to cut the hole behind
the battery compartment. made things much easier
Wait until you nail it for the first time
Old Mar 31, 2002 | 08:35 PM
Re: Re: PR CAI Instalation
2 and 1/4??? you mean 3 1/4............
Old Mar 31, 2002 | 10:06 PM
Nismo's Avatar
I used a 3.25 hole saw. I sawed it in the correct spot but I had to enlarge the hole onto a oval becase the filter was large and was hitting the fender wells.
Old Apr 1, 2002 | 09:20 AM
XXXL Cracker's Avatar
This is a great mod
After I completed the install on this, I was blown away by how loud my car sounded at WOT
Take your time. The directions I got were not 100% accurate.
I also did not remove the air temp sensor from the ram air scoop, black thing that is bolted to the top right of your radiator. On my 1997, I had to remove the sensor and the grommet from the ram air scoop and replace it in the CAI. There was a hole for it on my intake tubing. I also removed the whole ram air thing from my car because it took up a lot of engine space and IMO was useless.
When you go to drill the hole, make sure you move the fuse box and battery as far out of the way as possible so you are able to cut the hole properly.
Good luck!
DL
Old Apr 1, 2002 | 12:21 PM
RedMax95's Avatar
Re: Cool MOD
on another note, i would suggest you get new hoses for the two larger ones that go into the resonator, you dont want to be making a midnight trip to autozone like i did
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
