need help with built-in garage door opener
Old Mar 31, 2002 | 01:43 PM
TN-Max's Avatar
i have a 98 GLE, i dont have an owners manual (anyone that doesnt want theirs i will buy it), and im wondering if someone can tell me how i program this three button built in garage door opener?
Thanks,
Tom
Old Mar 31, 2002 | 02:04 PM
thezcarguy's Avatar
Re: need help with built-in garage door opener
Thanks,
Tom
I think this is how I did it...
First hold the two outside buttons ( 1 and 3 )
when the light stays on hold the button that you wanna program while pushing the garage door opener button. when the button is programed it will start flashing..... Again this is just off the top of my head and Im not 100% sure of its accuracy but its close.. hope this helps.
John.
Old Mar 31, 2002 | 02:10 PM
TN-Max's Avatar
thanks, ill go try this right now
Old Mar 31, 2002 | 02:23 PM
FLO_BOY's Avatar
if it doesn't work, I can grab my manual...just ask.
FLO_BOY
Old Mar 31, 2002 | 02:29 PM
teraspeed's Avatar
Check out Homelink.
Spencer
Old Mar 31, 2002 | 03:44 PM
TN-Max's Avatar
thanks for the help guys, it took me a little while but i got it working, apparently my garage door opener is a rolling code type opener, so it took me a little while to figure it out because the directions provided on the website didnt work with my opener
Old Mar 31, 2002 | 03:48 PM
FLO_BOY's Avatar
If you got the built-in opener to work with your rolling-code type opener, than I would love to know how...because, with non-rolling code openers, you are simply "lifting" the code into your Maxima's built-in opener...BUT, rolling-code openers use a new code every time
to ensure that others aren't "lifting" your code nearby...That said,
I can't get my Max to open a door with a rolling-code opener...
DAMN, that sounds confusing...
FLO_BOY
Old Mar 31, 2002 | 03:56 PM
TN-Max's Avatar
k, ill explain how i got it to work, it basically took trial and error of different methods because the directions on homelink's website did not work for me..here goes: on the back of my garage door opener there was a red button that is a transmitter to the remote openers in both of my other cars, i had my dad hold down the homelink button on far right side in the maxima and one second later i pushed and held the red code sender button on back of garage door opener, we both held for about 5 seconds after that and then it was programmed and working....basically on a rolling code opener (and yes it is rolling code because it says so in the manual) u need to install the homelink system the same way u did ur remote openers in ur car(s); it worked for me, try it and if it doesnt work let me know and let's see if we can't think of something else that will
Tom
Old Apr 1, 2002 | 05:46 AM
BEJAY1's Avatar
Conecarver
That's cool. I've never heard of anybody getting a rolling code type to work without the plug in adapter.
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
magiconthetire
Oct 26, 2015 09:03 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
