Rough Idle and jumpy RPMS
Old Mar 31, 2002 | 11:36 PM
AIKNEE's Avatar
I have a 1996 nissan Maxima SE. I recently got it and am still doin work on it. I've replaced the plugs and I've takin the car into the shop to get it looked at. But when I start the car and have it running for awhile and I am stopped at a red light the rpms drop dramaticly. sometimes it'll sit on the brink of a stall. so the car shudders at times. I've cleaned out the fuel lines, checked my pumps, and changed fuel filters. what the heck is goin on? oxy sensor?
Old Mar 31, 2002 | 11:41 PM
Nismo's Avatar
Try cleaning out your Throttle body. that might help with the idle problems
Old Apr 1, 2002 | 05:47 AM
caneyebus's Avatar
how do you do that or is it one of those take it to nissan things???
Old Apr 1, 2002 | 05:57 AM
kvzeyde's Avatar
cleaning throttle body
check out www.motorvate.ca Also try a search for "throttle body cleaning" I predict cleaning the TB will help solve your problem.
Old Apr 2, 2002 | 10:20 PM
Larcenist's Avatar
you should also check your idle setting... make sure its not too low.
Old Apr 2, 2002 | 10:22 PM
FLO_BOY's Avatar
same thinng had been happening to me -- cleaned Throttle body, and replaced my Knock Sensor...the car drives MUCH better...anyhow, I just wanted to let you know that you're not alone.
FLO_BOY
Old Apr 2, 2002 | 11:30 PM
AIKNEE's Avatar
good deal. thanks all for the help. I might replace my sensors but I am definitly cleaning the throttle body this week. speakin g of which, does any1 know of a site where I can get directions on how to change my sensor?
James
Old Apr 3, 2002 | 08:50 AM
CJP's Avatar
CJP
There was a recall for 02 sensors on 95 and 96's I believe. I had all of mine replaced for free from a dealer even though I'm the second owner and have 66000 miles. Another one went out recently and I had that replaced for free as well. I had the rough idle problems like you did and it turned out my base idle was off. Dealer took care of that too.
Old Apr 7, 2002 | 04:31 PM
AIKNEE's Avatar
Thanks.
Hey guys, I just wanted to say thanks for all the help I got. I did cleaned out my thorttle body and now maxi goes zooooom. it was pretty tight. anyways, thanks again!
James
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
