Intelliglow gauge needle installation on a 96(PLEASE HELP)
Old Apr 1, 2002 | 11:41 AM
2maxout's Avatar
I've got everything apart and ready. I just need to know how to safly take the needles of w/out messing anything up. If anyone has sucessfuly done this or just any info it will be greatly appreciated. I have a 96(If that helps) Thank you.
Old Apr 1, 2002 | 01:04 PM
guido_sst's Avatar
You need to grasp them firmly and gently tug while turning them clockwise.
Old Apr 1, 2002 | 01:16 PM
2maxout's Avatar
Ill give that a try. Thanks a lot. If i do mess it up is there a way to fix it?
Old Apr 1, 2002 | 01:31 PM
zboy's Avatar
Just go slowly and carefully and you won't mess it up. Rushing is your worst enemy here. If you do what guido said, you should be fine (just don't forget to calibrate them).
After I took my needles off, I also used a hairdryer to help loosen the glue holding the faces on to the guages so i could take them off. Then I put the intelliglow led's on and stuck the faces back on (the glue still held them) so that the wires for the intelliglow led's ended up under the faces.
-zach
Old Apr 1, 2002 | 01:32 PM
guido_sst's Avatar
If you screw up the cluster, the only way to fix it is to replace the gauge, not a cheap proposition. Just work slowly and don't try and force anything and you should be fine.
MaxLife17
Jun 27, 2019 01:37 PM
captchaos
Mar 15, 2016 12:18 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
