Any Draw Backs To Y-pipe
Old Apr 1, 2002 | 03:58 PM
SeBlackMax97's Avatar
i am going to order a y-pipe from warpspeed performance but i was wondering if there are any drawbacks to a y-pipe. all you hear about is good things, is there nothing wrong with them? also i live in AZ and i am wondering if i should get the stainless steel or the aluminized? cost isnt really a factor i just want the best possible product for the money.
Old Apr 1, 2002 | 04:00 PM
Jeff92se's Avatar
I'm needing a caw
AZ? Forget SS it's not needed.
Only drawback is the permanent smile on your face. (could cause wrinkles!!!!)
Old Apr 1, 2002 | 04:05 PM
SuDZ's Avatar
That and the extra cost of gas you will have to spend from doing extra driving at full throttle.
You will love you Ypipe once you get it installed.
SuDZ
Old Apr 1, 2002 | 04:15 PM
95emeraldgxe's Avatar
no drawbacks, just slap it on and hit the pedal ...... yes - jeff is right about that permanent smile thing - lol
Old Apr 1, 2002 | 04:58 PM
did you guys put the pipes on yourself or did you have someone put it on? how much?
Old Apr 1, 2002 | 05:20 PM
bandera311's Avatar
where in az are you from?
Old Apr 1, 2002 | 05:22 PM
gilbert/mesa area
Old Apr 1, 2002 | 08:24 PM
SuDZ's Avatar
Did it myself. The rust made it tough to undo the bolts on the cat, but your in AZ so maybe you dont even have any. It is basicly an hour job to do.
SuDZ
Old Apr 1, 2002 | 09:07 PM
97MaximaSE-L's Avatar
hey mesa/gilbert AZ guy, you gonna make it to our meet on saturday?
Old Apr 1, 2002 | 09:12 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Which brand y-pipe do you own?
Old Apr 1, 2002 | 09:36 PM
BriGuyMax's Avatar
I put my Cattman pipe on myself...the only problem with it was that he has been unknowingly using defective flex sections for the last year and a half...and now he has to fix a bunch of pipes under warrenty....
Old Apr 1, 2002 | 09:42 PM
Dave B's Avatar
Not DAVEB the parts guy
A Y-pipe will add more noise. The stock y-pipe has thicker gauge metal and precats which deaden a lot of noise exhaust noise (just not muffler noise) Y-pipes, depending on make, will introduce some vibration into the car. This vibration is very very minimal with the Warpspeed and slightly more on the Stillen. I've owned both so I know I hear the Cattman can vibrate pretty badly. Why do the Y-pipes cause vibration? Because of the shorter flex sections vs stock flex section. The shorter the flex section, the more the vibration.
Dave
Old Apr 1, 2002 | 10:10 PM
Eric L.'s Avatar
I have the Cattman SS Ypipe. I would say the drawback is that the car sounds little less refined than with the stock pipe. Idle sounds much coarser and of course, your engine emissions are unlikely to be within legal limits at idle speed due to lack of precats.
Old Apr 1, 2002 | 10:49 PM
Miguel97GLE's Avatar
Hey
I just ordered my Aluminized Y-Pipe from Warpspeed. I'm also in the Mesa/Gilbert area. Maybe we could do the install at the same time.
Old Apr 2, 2002 | 05:18 AM
WaydeMax's Avatar
Yeah, I read somewhere that there is one minor drawback. Don't you have to drive around for 45-60 min. prior to emissions test just to pass? would something like a new RT Cat prevent this ?
Old Apr 2, 2002 | 05:41 AM
deezo's Avatar
Yes. The pipe needs to be good and hot.
Old Apr 2, 2002 | 10:35 AM
bigmaxhi's Avatar
Dave
So the warpseed y-pipe makes the least noise. is there any way to stop the noise?
Old Apr 2, 2002 | 10:39 AM
Jeff92se's Avatar
I'm needing a caw
Yeah, but then it would probably drive up the cost of the Y 3x.
Old Apr 2, 2002 | 10:41 AM
Str8ridin's Avatar
Kepp your stock exhaust on and you should be fine. When you start using aftermarket exhausts, that's when the Y-pipe can make your car get pretty loud....
Don't worry about power loss with keeping your stock exhaust, maybe 2-5 hp MAX...sometimes less.
Old Apr 2, 2002 | 01:38 PM
dwapenyi's Avatar
RT CAT improves flow, not so much emissions. The stock cat is probably best for emissions.
DW
Old Apr 2, 2002 | 03:12 PM
WaydeMax's Avatar
DW
Ok, i didn't think it would, just wondering tho'.
Old Apr 2, 2002 | 07:57 PM
iregula's Avatar
www.budgetexhaust.com
175 shipped!
Old Apr 3, 2002 | 05:34 AM
2DMax's Avatar
More info on these defective flex sections please....
I got my Cattman through the last group deal, and have yet to put it on, is this something I have to deal with?....thanks !
Old Apr 3, 2002 | 07:02 AM
Str8ridin's Avatar
I got mine from the last group deal and email Cattman to see if I should be concerened about the flex section. He said not to worry and put the pipe on and just go from there. If there is a problem, he can send a fix pack in the mail.
Although, one word of caution with the pipe you got from the group deal: A few pipes from that batch were welded incorrectly (the buttweld on the Y is about 1/4 inch off) so your pipe might be defective. Mine was and it was a hassle to install, un-install send it back then re-install it. Cattman will pay for the shipping to and from, but won't cover the cost of installing/un-installing.
I'm sure yours is fine though because alot of them were fabricated correctly...but just wanted to let you know.
Old Apr 3, 2002 | 07:08 AM
SuDZ's Avatar
Wrap it with header wrap.
SuDZ
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Justin Kroll
Sep 2, 2015 11:06 AM
