what's a popcharger?
Old Apr 2, 2002 | 07:07 PM
xsp00kyx's Avatar
what is a popcharger?
Old Apr 2, 2002 | 07:13 PM
teraspeed's Avatar
It's the thing that puts bubbles and fiz in your softdrinks. Popcharger.
Sorry, couldn't help it. It's basically a conical shaped performance air filter.
Old Apr 2, 2002 | 07:14 PM
maximumsportZ's Avatar
Lives in a 350Z
Battle of The Newbies.
Old Apr 2, 2002 | 07:25 PM
clee130's Avatar
It's basically a fancy name for the Stillen or Jim Wolf Technologies (JWT) intake.
Old Apr 2, 2002 | 07:27 PM
grody's Avatar
anybody know why it's called a popcharger?
Old Apr 2, 2002 | 11:02 PM
95emeraldgxe's Avatar
jwt is a rip - why spend 120 when u can get the exact same thing for about 40
Old Apr 3, 2002 | 07:38 AM
ymNA's Avatar
I'm planning on getting a K&N filter at autozone and get the adapter i see on ebay... would this work? ANd I see a lot of people saying that the car will lose low end,, is this meaing worse then stock or just no improvement over stock?
Old Apr 3, 2002 | 10:14 AM
xsp00kyx's Avatar
what does low-end mean?? thanx
Old Apr 3, 2002 | 10:46 AM
Max96LSU's Avatar
Low end torque. It means your car will pull harder in lower RPMs. Most air intake though will give you high end torque. Do a SEARCH, this topic has been answered MANY times!
Old Apr 3, 2002 | 10:49 AM
Anachronism's Avatar
I belive the term pop charger is owned by JWT, but it kind of gets applied to all underhood intakes. The difference between the JWT Pop charger and a cone filter is the JWT pop has a Velocity Stack. A Velocity Stack is kind of a horn shape that is supposed to smooth the flow of air and increase the amount of air taken in. I would guess the term pop charger has something to do with the velocity stack. Why this velocity stack increases the price by almost $100 over a cone filter
'Low End' means power in the lower RPM ranges, there is much debate about this but the general cosensus seems to be that automatics will feel a low end loss, but 5 speeds will not notice it as much.
Edit - BTW here is JWTs Pop charger page, the ring in the pic at the upper left is the velocity stack.
http://www.jimwolftechnology.com/poprest.htm
Old Apr 3, 2002 | 10:58 AM
1/3There2/3ToGo's Avatar
I believe you have been mis-informed.
Low-end is only torque(idle to 3500 RPM0. Top-end is horsepower(3500 to red). If you get the Popcharger you will gain a few lb/ft of torque but it will feel like you "lost" power because of the significant gains in horsepower in the upper RPM band.
If you want more Torque get a CAI.
Kirk
DO A SEARCH!
Old Apr 3, 2002 | 11:02 AM
mzmtg's Avatar
Minister of Silly Walks
Kirk
DO A SEARCH!
You are so wrong!
Horsepower is merely a mathematical product of torque. The only thing that can be directly measured from an engine is torque. HP is (torque x RPM) / 5252.
That's all. There is no range of engine speeds for one or the other.
Geez, how many times does this have ot be re-hashed??
Old Apr 3, 2002 | 02:47 PM
Toolrocks's Avatar
I thought POP was for Ported Out and Polished, referring to the velocity stack. I think charger was coined since the velocity stack is supposed to (physics beyond the scope of this text) allow more air into the engine. All things equal of course. Do a search, there is a ton of info. on the various intakes for our cars along w/ pros and cons. I personally have the Stealin POP but if I were in the intake market again I'd probably get the Warpspeed Productions Cold Air Intake (WSP CAI)
Old Apr 3, 2002 | 03:22 PM
clee130's Avatar
Get a hybrid!
Popcharger + CAI upper piece
Best of both worlds
Old Apr 3, 2002 | 04:00 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Popcharger? Should be called lagcharger...bottom line is if you are automatic than you will lose torque off the line and you will definatally feel the lag with every "bum bum bum" sound the filter makes.
Ask Clee, he will 100% agree that a cold air intake owns and beats the cone intake like a red-headed stepchild.
Old Apr 3, 2002 | 08:21 PM
Originally posted by mzmtg
You are so wrong!
So....every single dyno ever done is inaccurate?
I guess this needs "ot" be re-hashed until there is a clear consensus for one side or the other
Mahmuth
Sep 25, 2015 10:08 AM
libo74
23
Mar 10, 2002 05:26 PM
dmbmaxima2k2
Mar 1, 2002 05:24 PM
GotMaxt
Feb 24, 2002 05:40 PM
ne max
Dec 15, 2001 09:28 PM
