Help! with jacking / floorstand points
Old Apr 11, 2002 | 08:50 AM
rmb's Avatar
rmb
Doing a strut/spring replacement this weekend..
I've got two large floor jacks and 2 jackstands...
I'll be lifting one end at a time.
Where do I jack/support the front end and jack/support the rear? 4th gen of course...
Thanks!
-RMB
Old Apr 11, 2002 | 09:16 AM
sinewave's Avatar
For the front, I use the motor mount bracket that runs down the middle of the car from the radiator to the bottom of the firewall. There is a protrusion that is a natural fit for a jack.
On the rear, I place the jack in the middle of the beam axle. You get a little flex in the axle, but it will do no damage.
Old Apr 11, 2002 | 09:40 AM
rmb's Avatar
rmb
Thanks... I've got the Stillen RSB though which is right smack behind and a little below the rear beam.... I don't think I'd want to jack on that... lol...
Anywhere else in the rear?
-RMB
Old Apr 11, 2002 | 10:29 AM
Big_Ham's Avatar
MaximaFreak
Re: Help! with jacking / floorstand points
Thanks!
-RMB
Dude, help with jacking is a little off topic for this forum, eh? Besides, you should have learned that at around 13
Old Apr 11, 2002 | 10:52 AM
sbslacker's Avatar
Thanks!
-RMB
Raise the car from where sinewave spoke about....place the jackstands where the owner's manual tells you to jack the car from when fixing a flat tire...you know, between the notches on that ridge that runs along the bottom of the car.
Also, after you've got the car resting on the stands, remove the jack from the rear beam. You want that thing hanging by itself when you do the swap.
Old Apr 11, 2002 | 11:15 AM
csnow's Avatar
I'll kill you. I mean it
Re: Re: Help! with jacking / floorstand points
Originally posted by Big_Ham
Your last post made you look like an A$$.
"Dude, help with jacking is a little off topic for this forum, eh? Besides, you should have learned that at around 13"
Old Apr 11, 2002 | 02:01 PM
ptatohed's Avatar
Licensed to Spell
:o)
I came across this problem too when I was installing my supercharger. Until then, I had only used the stock jack at the stock points (where the 'notchies' are). But now I was using two - 2-ton jacks. The little bowls on the jacks would bend the 'notchies' had I placed them there. So what I did was place them exactly at the notchies but on the other side of the wall (towards the inside of the car). Does that make sense? Hope I helped. Good luck.
Old Apr 11, 2002 | 02:32 PM
Big_Ham's Avatar
MaximaFreak
Re: Re: Re: Help! with jacking / floorstand points
Originally posted by 1eyedcalibandit
Glad I was able to achieve my goal. By the way, next time, post your response outside the QUOTE markers.
Old Apr 12, 2002 | 10:55 AM
mango95se's Avatar
When i did the rear, i found it easier to lift one side at a time. I lifted it at the beam and then put the jack stand slightly towards the front of the car - where there are rail looking things under the body.
-RMB
Old Apr 12, 2002 | 04:10 PM
csnow's Avatar
Re: Re: Re: Re: Help! with jacking / floorstand points
nah I like them the way they are, besides your posts help everyone...
"Glad I was able to achieve my goal. By the way, next time, post your response outside the QUOTE markers".
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
