Alteezas
Old Apr 11, 2002 | 06:51 PM
MIXXMAX's Avatar
Alteezas
I know this is a touchy subject for that many members don't like these lights, but a question for the people who have them installed on their cars...anybody have problems from other cars seeing you signaling when turning? I have these lights installed on my car and I have been told that people have a hard time noticing my signal, especially when the parking lights and brake lights are on at the same time! It seems that these particular lights share the turn signal lamp and brake lamp all in one unit. I believe these lights should have been manufactured with a "seperator" inside the housing to seperate the two (like the stock ones). This way the turn signal lamp will illuminate brighter without fighting with the brake light. What do you guys think? Any suggestions, or did anybody do any mods on correcting this particular problem? I was thinking of swapping the inner brake lamp for the turn signal lamp, so that only the outer lamp is for braking and the inner lamp for signaling and reverse. But, I believe this is illegal for that turn signaling on the rear of vehicles must be somewhere on the outside corners. Right? What do you guys think?
Old Apr 11, 2002 | 07:22 PM
Paradoxish's Avatar
I should say I don't like Altezzas and I don't have them installed on my car, but I have seen a few Maxima's with them and I can say that it can be hard to see their turn signals. But no harder than a lot of American cars that share a turn signal and brake light.
Old Apr 12, 2002 | 04:25 AM
metallic97gxe's Avatar
Master Will
I have Eurolite 1157 LED's as my brake/park lights and regular 1156 bulbs as my turn signals they are an obvious difference in color and brightness...
Old Apr 12, 2002 | 08:17 AM
Sexima's Avatar
look at mine
^^ they dont really give a damn about my lights
cop was right behind me one day cause of accident and he didnt say shiet to me about it
Old Apr 12, 2002 | 01:49 PM
DOWN LOW's Avatar
I agree, i have them installed and that has been my major problem. Having people notice me signal. It is not too bad when you just have on the parking lights, but when you hit the brakes you can barely see them flash. I am going to try and wire the two little lights at the outermost corner to flash when I signal. That's the only solution i see.
Old Apr 12, 2002 | 09:53 PM
MIXXMAX's Avatar
Are you talking about the side marker light in the corner? If so, these lights aren't really bright for that they are only a 4 watt 194 bulb. I wonder if there is a way where we can make the brake light lamps flash for the turn signal. (As if it was all one lamp--brake, parking lights, and turn signal).
Old Apr 12, 2002 | 11:47 PM
rguida's Avatar
this worked for me.....try putting blue (yes blue) colored lights for your brakes/parking I.E. 1157......then put some high wattage bulb in for your 1156s......the blue bulb is not bright to begin with so it will dimly light the bottom but will still be visible.. when you turn on your signal its light output will be unrivaled by that of the blue bulb.
Old Apr 13, 2002 | 09:22 PM
MIXXMAX's Avatar
Originally posted by rguida
this worked for me.....try putting blue (yes blue) colored lights for your brakes/parking I.E. 1157......then put some high wattage bulb in for your 1157s......the blue bulb is not bright to begin with so it will dimly light the bottom but will still be visible.. when you turn on your signal its light output will be unrivaled by that of the blue bulb.
Thanks! I'll give it a try!
Old Apr 14, 2002 | 08:06 PM
Maximuzt's Avatar
I've had no problems with anyone seeing which way I was turning with the signals, and I have regular bulbs
Old Apr 15, 2002 | 04:55 AM
BRIGBOY's Avatar
Lucky you
Originally posted by Sexima
look at mine
Because your tails are now illegal until you install a red side marker on your rear 1/4 panel that is wired in with the brake lights.
Old Apr 15, 2002 | 11:31 AM
Sexima's Avatar
i gotta go get inspection soon...
you guys think i'll make it?
Old Nov 17, 2005 | 05:40 AM
davids's Avatar
1995 Maxima Driver's Seat Belt Replacement
How do I replace? Sorry for posting here but can not start new thread.
Old Nov 17, 2005 | 06:19 AM
MaDMvD's Avatar
Oh man, you've just unleashed the hounds of hell...
Old Nov 17, 2005 | 06:28 AM
maxgtr2000's Avatar
KH3 by popular demand
Chiltons manual or Haynes manual, you do have a manual correct? It is required before you register. You did read the rules right? And all the stickies. If not take seat belt, wrap around neck, and pull tight.
Old Nov 22, 2005 | 05:43 PM
NYC32798's Avatar
I got a question about the gen 2 altezzas. I got a 96 max so these won't fit. As of now I know they make them for 97-99 models but not 95-96. Has anyone heard of these coming out for 95-96's?
Old Nov 22, 2005 | 07:19 PM
lilaclucymaxima's Avatar
Team Ramrod
I've never heard of that happening. Just get a '97-'99 trunk lid so you can get gen II's.
Old Nov 23, 2005 | 06:03 AM
buttonhook's Avatar
Stillen Now sells them!!
Old Nov 23, 2005 | 06:35 AM
Team Ramrod
Are you sure? Didn't find them on the Stillen website.
Old Nov 23, 2005 | 07:02 AM
Doc's Avatar
Doc
Why do so many people insist on spelling Altezzas incorrectly? People, it's not Alteeza...sorry to interrupt with my soap box.
Old Nov 23, 2005 | 07:56 AM
MAXRB8's Avatar
Gen II Altezza's in a 95-96 trunk! Voila! cutting required:
Old Nov 23, 2005 | 08:17 AM
buttonhook's Avatar
Call them
in their christmas catalog they show them as being "NEW" for 95-96's.
Old Nov 25, 2005 | 12:20 PM
NYC32798's Avatar
Call them
I called Stillen and they said they don't exist. I even called the place Stillen gets their parts from and they also said they have never heard of them.
Old Nov 25, 2005 | 03:08 PM
DR-Max's Avatar
I have followed a maxima with Gen I Altezzas and I couldn't even tell he was signalling....a major minus for these tails in addition to their hideous looks. Gen II's look sexy on maxes though, totally different look. But my number one choice is my red/clear.
Old Nov 26, 2005 | 04:01 PM
ohflguy's Avatar
the danger i see is distinguishing the signal. I dont have them tho.
Old Nov 26, 2005 | 06:34 PM
MIXXMAX's Avatar
Wow! You talk about a thread coming out of the past! I was just surfing the 4th gener. forum and came across this. I started this thread over 3 years ago! Wow, how things still continue on!
Old Nov 28, 2005 | 06:19 AM
buttonhook's Avatar
does anyone else have a new stillen catalog???? On page 61 do they not show them for the 95-96 maximas or am I losing what little mind I have left????
Old Nov 30, 2005 | 07:52 AM
buttonhook's Avatar
eBay home | Pay | Register | sign out | Site Map | Community | Help
Search eBay Motors Advanced Search
Back to list of items Listed in category: eBay Motors > Parts & Accessories > Car & Truck Parts > Lighting & Lamps > Tail Lights
95-96 NISSAN MAXIMA G3 CHROME ALTEZZA TAIL LIGHTS LIGHT Item number: 8017439232
You are signed in Watch this item in My eBay | Email to a friend
Larger Picture
Starting bid: US $58.99
price: US $59.99
Time left: 5 hours 57 mins
7-day listing, Ends Nov-30-05 14:02:48 PST
Start time: Nov-23-05 14:02:48 PST
History: 0 bids
Item location: CA
United States
Ships to: United States, Canada
Shipping costs: US $19.99 - Standard Flat Rate Shipping Service
Other shipping services available
Shipping and payment details
Seller information
speedfantasy ( 3155)
Positive Feedback: 97.5%
Member since Jun-09-04 in United States
Read feedback comments
Add to Favorite Sellers
Ask seller a question
View seller's other items
Store view | List view
Visit this seller's eBay Store!
SPEED FANTASY FANTASTIC STORE
Shop without sharing your financial details Learn more
Description
BRAND NEW IN ORIGINAL BOX!
EXACTLY SAME AS PICTURE !
COME WITH BOTH SIDES!
S.A.E./D.O.T. APPROVED & STAMPED!
EASY TO INSTALL!
Item Condition : New
Payment Options: Money Order/Cashier's Check, Personal Check
Shipping Options: Fixed Shipping Charges.
Shipping Carriers: USPS First-Class, USPS Priority, USPS Parcel, UPS Next Day, UPS Second Day, UPS 3 Day Select, UPS Ground
Shipping Rate:
$ 19.99 (Domestic)
$ 29.99 (Canada)
For other international region shipping price, please email us for details.
Insurance Rate: $ 3
Sales Tax: 8.25% for in-state buyers
Shipping and Handling Charge
PO box, APO, FPO, HI, AK, PR, GU, VI and other countries, shipping and handling fees will cost more. Please email us for more detail
All shipments are made via UPS Ground or United States Postal Service either by regular airmail (3-5 days) or Priority Mail (2-3 days) depending on the types of products purchased. Majority of our orders will be within 2 business days (mostly within 24hrs) (All mail transit time stated above is best estimated but not guaranteed.)
All payments (Mail Payment / Paypal) need to go through the "Andale Checkout" to prevent delay in your shipment.
After you won the auction, an email with Andale Checkout procedure will be sent to your eBay registered email address.
All payment are expected within 7 days after the last winning auction is closed. We reserve the right to file Non-Paying Bidder Alert if the payment is not received 7 days after the auction ended,
Please be sure to ask all questions prior to bidding. When you bid, you are obligating yourself to the auction in the event that you win
Simply wait until all of the auctions are ended. Complete the checkout from the most recent email that you received from us.
Payment methods: Paypal , money order, and personal check (will be held until cleared.)
All sales are final, no refunds are available. We can only issue an exchange if the item is received defective or incorrect item shipped.
All return items MUST be in brand new condition which means the item is never installed and kept in the original packaging, otherwise a 15% restocking fees will be charged.
We will not resend product before we get a confirmation from insurance claim or the returned item from customers.
All shipping and handling fees are non-refundable in any circumstances.
Please inspect your order upon receipt. No claims will be honored after 7 days of delivery.
Shipping Cost Services Available Available to
US $19.99 Standard Flat Rate Shipping Service United States Only
US $29.99 Standard Int'l Flat Rate Shipping Canada
Will ship to United States, Canada.
Shipping insurance
US $3.00 Optional
Sales tax
Seller charges sales tax for items shipped to: CA (8.250%).
Payment methods accepted
This seller, speedfantasy, prefers PayPal.
Personal check
Money order/Cashiers check
Other - See Payment Instructions for payment methods accepted
eBay recommended services
This seller prefers to be paid with PayPal, the safe way to pay with your credit card on eBay. Sign up for PayPal it is free!
Old Nov 30, 2005 | 08:01 AM
86maxima96's Avatar
I Broke OT
what the he11 was the point of that?
Old Nov 30, 2005 | 08:05 AM
buttonhook's Avatar
he wanted to know where to get them they have them on ebay.
Old Nov 30, 2005 | 09:37 AM
DR-Max's Avatar
All he needed to do is post the link.
Old Nov 30, 2005 | 09:45 AM
ajcool2's Avatar
Thats noobs for ya. They'll learn one day.
Old Nov 30, 2005 | 09:50 AM
DR-Max's Avatar
I looked at the item in ebay, its no different from Gen 1 gaytezzas.
Old Dec 1, 2005 | 06:35 AM
buttonhook's Avatar
well I would have but it seems as though all my info has been unreliable (thanks stillen catalog) so I wanted to make sure that all the info got on here and that it was correct.
And he did not say what he wanted it was just asked where could he get some...so there it is.
Old Dec 1, 2005 | 06:48 AM
buttonhook's Avatar
First of all this is not directly related just at you.. but it was the last straw. Yes those of us that are newer to this site will learn one day. THANK YOU captain obvious!! Wasn't everyone on here new at one time??...."Nooby" it sounds to me that anyone that has to use that has some self issues. I saw where a guy with 50 some odd posts was calling someone with 30 some odd posts a "noobie". Is it some kind of special club you have to join. do you have to call someone a noobie at least once to get in to it?? You knowEVERYONE needs to give true constructive critisim instead of just calling names.
I feel a little better now. Now having said that I like this site I try to use the info I get on here and I try to give a little when I can. There is no name calling needed just because someone has less posts than you
Old Dec 1, 2005 | 06:53 AM
Iron Scimitar's Avatar
Tha Snatcher
okay, it's safe to say that this thread needs to be locked ASAP.
Old Dec 1, 2005 | 02:13 PM
ajcool2's Avatar
All of this because I said you were new to the site and that all you had to do was post a link which would have been a little easier???? Sounds like your the one with the issues dude.
Old Dec 2, 2005 | 05:38 AM
buttonhook's Avatar
If you will READ it's not the critisim it's the way it was done...........DUDE. And it was not a personal attack on you. it was an attack on the way the term NEWBIE it used. I think it is a used as a put down and needs to be stopped. If people were a little more understanding a helpful rather than just posting...That a newbie for ya. thing would go alittle better don't you think.
Kaleboi
Jul 10, 2012 08:33 AM
maxina97
Jul 31, 2010 07:57 AM
WillMax95
21
Nov 10, 2003 03:37 PM
pearl97
23
Sep 24, 2003 12:18 AM
