Max stalling for no apparent reason....help?
Old Apr 11, 2002 | 07:36 PM
Rooster286's Avatar
Here's the lowdown
95 Max
102k miles
Auto
Lately I've been getting a stalling problem from my max....it does not seem to occur at any other time then when I'm waiting at a light or stopped with the car in drive. it just flat out dies, no real sputtering or anything. had sparks, pcv, fuel filter changed last year, and change oil regularly (3k). It's not bad fuel, as I've gone through 2 or 3 different tanks of gas from different places since this started. once i put car in park and try to restart, it basically starts right back up and off I go. Today however, when it happened I started back up, threw it into drive and it almost died again, but it seemed to catch and it was fine all the way to work. Anyone have any ideas?? tranny has been shifting kinda weird lately, but I don't see how that would affect it.....but then again I really don't know if it would or not, so I'm asking you guys. The help is appreciated! Thanks!
Old Apr 11, 2002 | 08:11 PM
Nismo98's Avatar
Check your MAF sensor. I had same **** a year ago.
Andrei
Old Apr 11, 2002 | 08:26 PM
i30dude's Avatar
Yep Check the MAF and the air temp sensor. I bet its the MAF. Clean out your intake manafold too.
Old Apr 12, 2002 | 02:10 AM
JPMontoya's Avatar
1. Get the battery checked for free at Pep Boys (you'll have to take it out and put it back in), to see how good it is.
2. Could be a dirty Throttle Body.
3. Check what Nismo98 & Rooster286 suggested.
Old Apr 12, 2002 | 02:18 AM
Nismo98's Avatar
I had this problem about a year ago. I have a 5 speed and every time I would get to a red light or just be on nutral, my car would start choking and just die, so I had to restart it. My buddy hooked it up to a scanner and told me right away it's a MAF. After that I went to Nissan Dealer and he told me same ****. That little fu*king thing is expansive as f*ck, I think around $ 400. After I found that out, I bought the extanded warranty right away.
Andrei
Old Apr 12, 2002 | 08:54 AM
Rooster286's Avatar
?!?!?!?!?!?!??! 400.00!>!>!>
jesus!!! thanks for the info guys, junkyard here I come!
Old Apr 12, 2002 | 09:20 AM
mango95se's Avatar
I had the same problem and it was my IAC valve. might try to remove it and clean it or possibly replace it.
Old Apr 12, 2002 | 09:27 AM
Eric L.'s Avatar
I know on fuel injected Toyotas there is a phenomenon where you begin to lose power, then the car stalls. This happens gradually over time. The problem is the TPS (throttle position sensor). I would check that as well. Easy to do with a multimeter.
Old Apr 12, 2002 | 11:25 AM
Nismo98's Avatar
Rooster286, did you change your intake or do you have your stock one.
Andrei
Old Apr 12, 2002 | 11:28 AM
Rooster286's Avatar
still stock, cause I'm too poor to afford CAI
Anyone know where I can get a Chilton's/Haynes(sp?) manual? websites to buy from etc......damn parts stores NEVER have 4th gen...always 3rd gen books.
Old Apr 15, 2002 | 06:16 AM
mango95se's Avatar
I got the Chilton's at O'reilly and the Haynes at Autozone. it looks like only 3rd gen, but its both third and fourth gen. something like 1993-1998 maximas.
Old Apr 15, 2002 | 07:21 AM
got rice?'s Avatar
run the ecu diagnostic and see if any codes come up. it'll give u a place to start looking.
Old Apr 16, 2002 | 12:01 PM
maxnewbie's Avatar
In other words, it could be anything.
Old Jun 18, 2002 | 12:03 PM
FLO_BOY's Avatar
Re: Max stalling for no apparent reason....help?
Here's the lowdown
Did you ever figure this out?
I had similar problems and it turned out to be loose ground wires
that connect to the knock sensor -- the bolts are near the fuel rail
toward the "front" of the engine...if you search for my thread entitled "did I finally fix my car", there's an image to point them
out.
best,
FLO_BOY
Old Jun 18, 2002 | 01:33 PM
NotNew!!NewSN!!'s Avatar
my money is on this one, same happend when my idle air control valve went, make sure to check this
Old Jun 18, 2002 | 02:11 PM
karguy's Avatar
From time to time The Nissan Factory Service Manual is available on EBay, one copy went for $31.50 and the last one for $71.00, I paid $119.00 for mine when I ordered it from Nissan. I believe it is far superior to Haynes which I also own.
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
