Air Intake
I just finished installing my Ractive conial filter but have a problem. After I installed the air filter, it now touches the fender underneath. I know that when you buy a stillen intake it comes with a bracket. Is the bracket meant to hold up the intake housing? If it does, does anyone know where I can get one?
Had the same problem when I installed my intake. I found some backstrapping used for car audio installation to support my intake filter from the MAF adapter to the fender using the existing bolt holes. You can probably get the backstrapping at a hardware store.
You can also put the bottom half of the stock filter box back in and the new filter should rest on it perfectly. The box will also protect it from some engine heat. But either way you won't notice it.
tarun900
19
12-20-2021 06:57 PM
maxima297
09-30-2015 03:32 PM
