Knocking when driving slow
Old Apr 30, 2002 | 10:58 AM
Kehops's Avatar
I've had this problem for the past couple days now, when coming to a full stop while slowing down(5-10miles/hour), I can feel a knocking sensation coming from underneath the brake pedal it feels like. This isn't under hard braking but under any braking when coming to a stop. Brakes are new by the way.
Any help would be appreciated
Old Apr 30, 2002 | 11:57 AM
njmaxseltd's Avatar
Were your rotors turned? Sounds like a bad spot or a crack in a rotor.
Old Apr 30, 2002 | 01:10 PM
Kehops's Avatar
Maybe...but it doesn't feel that way, it doesn't do it all the time.
I forgot to mention that when parked with the car off, if I press on the brake pedal, I can hear a lose bolt moving, then the sound stops and if I press again and release, it'll come back and keep doing it for 5secs or so until it stops moving....it's weird
Old Apr 30, 2002 | 01:44 PM
MaximaRacer's Avatar
Get your head under there and take a look. Its dangerous to have things loose for the brake pedal.
Old Apr 30, 2002 | 03:50 PM
KWheelzSB's Avatar
1st:
-if you had a shop perform the work, take it back to them & demand that the problem be resolved.
If however, you/friend did the work:
+jack the car up & place on jackstands
+remove the wheel(s) from the suspect side(s)
+visually inspect for anything obviously wrong
+check that pads are seated correctly in retaining clips
+inspect rotor surfaces for cracks or other damage
+torque all bolts to factory specs: (torque member bolts, caliper pin bolts)
+replace wheels, torque lug nuts to spec. test drive.
Let us know how it goes.
Mar 12, 2020 12:06 AM
ballerchris510
Sep 23, 2015 08:46 PM
ag90fox
Sep 9, 2015 12:22 PM
