Low Washer Fluid Light
Old May 11, 2002 | 09:40 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Although my SE doesn't have the cold package that comes w/ the washer fluid light, and I'd like to know by a light when I'm low on washer fluid, so is it still possible to add a low washer fluid light to the dash and add all that sensing stuff from underhood or does the dash have to be changed just to get that particular light? How would I go at this? Or am I S.O.L.?
Old May 11, 2002 | 09:43 PM
Toolrocks's Avatar
Sorry, I can't help you. I've seen this covered once before but a search didn't yield me any results. If I remember correct there is a wire all ready in place. I think it easy to hook up, I just don't remember. So, I am jumping into this thread to stay informed.
Old May 11, 2002 | 09:57 PM
97MaxSE's Avatar
Yeah I have a 97 Max SE. Why in the hell do we not have a low washer fluid light? I had one in my 90 Max SE. HELP>>>>>
Old May 11, 2002 | 10:30 PM
So if there already is a LWF (Low Washer Fluid) light in the dash & its all prewired, then it shouldn't take long to add the sender unit from the reservior or whatever, correct?
Old May 11, 2002 | 10:56 PM
jiaxima96's Avatar
There has been some posts that helped me install the sensor. Been a while but still remember that only the LWF sensor is needed. Drill a whole on the WF tank bottom, put sensor in and plug in the already existing connector. Done. My 96 GXE has S/C package but I'm not 100%sure if all Max has the sensor connector but it can be easily found if there is/isn't one.
Old May 12, 2002 | 01:35 AM
psu max's Avatar
http://forums.maxima.org/showthread.php?threadid=49049
should have part number and instructions in it
Old May 12, 2002 | 07:55 PM
Thanx
Then if it's prewired I'm good to go just by adding the sensor specified in that thread, correct?
cash94
Aug 27, 2015 08:09 AM
Maxgig
Aug 18, 2015 09:17 PM
egali045
Aug 16, 2015 01:19 PM
jchronis2552
Aug 13, 2015 07:48 AM
