fuse box under hood
Old May 14, 2002 | 11:40 AM
Ralph Wigum's Avatar
fuse box under hood
how do you remove the covers on the fuses? i already took off the box with the description on it. i tried pulling on but it wont budge.. my owners manual says use the fuse remover but i dont see any....
Old May 14, 2002 | 01:45 PM
Chunger's Avatar
My other car is a Hybrid
Re: fuse box under hood
I believe there is a fuse puller in the interior fusebox near your left knee...
Old May 14, 2002 | 06:19 PM
pocketrocket's Avatar
I hope you're not talking about the fusible links under the hood.
Fusible links come in ratings above 20A with a see-through cover where you can see if the fusible link has burnt or not. Doesn't look like the fuses under your dash.
Please clarify which one you're trying to pull out.
Some fusible links might be screwed down (I know the main fusible link in the older Attimas were screwed in position, you had to unsnap the housing cover to loosen the screws).
Old May 14, 2002 | 09:52 PM
i was trying to find out if my fuses blew out for my fogs. i checked under the steering wheel and those fuses weren't blown. so i should check the fuses under the hood right?
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
leatherneck
Sep 30, 2015 09:16 PM
