Jerk at idle.
Old May 17, 2002 | 10:14 PM
asianmusketeer's Avatar
Jerk at idle.
I changed my plugs to bosch P4+ and when i hit WOT on the highway it jerks. That's not the only problem. While at idle, my RMP is at 500, but it would jerk a little to 700 and goes back to 500. So i changed back to my old plugs and the problem still exists. I didn't not have this problem b4 i changed my plugs. help!!!!!!!
Old May 17, 2002 | 10:23 PM
EZ's Avatar
EZ
Sounds like a fuel problem to me. Maybe fuel pump is bad or just needs a fuel injector cleaning.
Old May 17, 2002 | 10:31 PM
spiff56747's Avatar
get some new NGK platinum plugs and see if the problem goes away. Bosch plugs don't work that well with our cars, maybe your ECU adjusted to them and needs time to adjust back.
Old May 17, 2002 | 10:39 PM
i changed my fuel pump about 10k ago, so ya think i should change it? what brand do ya recommand?ya think i need to reset my ECU?
Old May 18, 2002 | 08:36 AM
njmaxseltd's Avatar
When was your fuel & air filter changed last? Check your MAF sensor, make sure it's plugged in securely, also check the entire intake for leaks. Everything should be nice and tight. You may have some air bypassing the MAF.
Clean your throttle body and IACV valve if necessary. You can search this board for instructions.
Melissa40
Jun 30, 2017 10:04 AM
foodmanry
Sep 24, 2015 12:02 PM
magneto112
Sep 10, 2015 12:52 AM
maxima297
Aug 3, 2015 12:50 PM
