Are relays dealer only?
Old May 23, 2002 | 06:18 AM
elcid's Avatar
Just wondering if you can only buy relays from the dealer. Also how can you test to see if a relay is good, I got the instructions from the Haynes Manula but not sure what they mean by "fused wire" or something like that. How much are relays from the dealer? Thanks.
Old Sep 6, 2002 | 10:30 AM
ezra's Avatar
No answer?
I am wondering the answers to these questions as well. I think I have a problem with my horn relay and don't know how to test it or where to get a new one.
-Ezra
Old Sep 6, 2002 | 09:48 PM
JAIMECBR900's Avatar
Very seldom do relays go out. If they do, you can get relays just about anywhere. A relay is a relay is a relay. I bought the relay for the fogs at pepboys when I converted mine and installed factory fogs on my GLE. You may want to check things out before settling on the relay being your culprit. Post/search the problem and see if you can get other diagnosing ideas.
Old Sep 7, 2002 | 05:36 AM
karguy's Avatar
When I suspect a bad relay I swap it out with another relay of the same type and see if the problem changes. The next thing I do is check out the circuitry with a meter. I check such things as resistance, voltage, etc... At that point the only thing left is using a scope such as a Tektronic if you have access to one. Last thing is to buy a relay. In over 10 years of Maxima ownership experience I have never had to replace a relay.
Old Sep 7, 2002 | 10:27 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Agreed! In the 14 years Ive been installing alarms,remote starts,radios,amps,etc...I have yet to need to replace a relay.
--Don
D Mason
Jun 21, 2016 04:43 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
zmcneely13
Sep 26, 2015 02:26 PM
