Tried to reset my ecu and there is a major problem
Old May 29, 2002 | 05:38 PM
Corion's Avatar
Ok isn't the ecu on he passanger side hidden on the left under the consol? I turned the screw to "reset it" and it snapped, the screw just cracked in half, what do I do?
Old May 29, 2002 | 05:45 PM
davey6693's Avatar
Wrong side
The ecu is on the driver's side, to the right of the gas pedal. You can get to it by removing the black panel which is held on by 2 snap-on clips and piercing the thin plastic warning label which covers the screw, if needed.
Old May 29, 2002 | 05:49 PM
Corion's Avatar
Alright awesome.....but what screw did I snap then?
Also do I turn it counter clockwise to reset it or clockwise?
Old May 29, 2002 | 05:55 PM
luckee2bhere's Avatar
I have no idea why you guys are resetting your ECUs??? get extra power out of it after mods??? clue me in!
Old May 29, 2002 | 05:57 PM
synix's Avatar
Everything you need to know can be found here.
Old May 29, 2002 | 05:59 PM
davey6693's Avatar
I'm only just beginning to know my max so I have no idea what screw you killed. Hopefully nothing painful..
The Check Engine Light sticky will tell you all you need to know, but as I'm very bored - with a small/medium flathead screwdriver and the car in the ON position (but not running)....
1) Turn screw clockwise all the way until it stops
2) Wait 2 secs, turn it back until it stops
3) Immediately repeat 1)
4) Wait 2 secs, turn it back again.
5) If you've done it right the CEL will flash a 0505 at you. At that point I just turn the car off and then fire it up. The CEL will go out.
Old May 29, 2002 | 06:54 PM
MIXXMAX's Avatar
Re: Tried to reset my ecu and there is a major problem
There is no "reset/adjustment" screw for the ECU on the passenger's side! Maybe, you snapped the "mounting" bolt that secures the ECU?
Old May 29, 2002 | 07:44 PM
CitrusSpeed's Avatar
doesn't the ecu adjust autmotically after a tank or so of gas?
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
Colossus
Sep 9, 2015 05:46 AM
