Trunk doesn't "pop up" anymore.
Old May 30, 2002 | 09:00 AM
Kevin's Avatar
there used to be a time wherne I'd hit the button and the trunk would ope up a little. Now it doesnt even crack open, I have to give it a nice pull. Alomsot like its stuck to something? anyon have that happen? I was rear ended once but that was a very minor collision and I didn't notce that effect right away.
Old May 30, 2002 | 09:08 AM
PhatBastard's Avatar
Does it still make the "clunk" sound as though it has tripped the lock when you press the button?
Mine did this once. It made the "clunk" sound but the trunk didn't pop up.
Let me know if this is your case and I'll go look at mine to see how I fixed it. Easy fix if it's the same problem.
NmexMAX's Avatar
dot dot dot ...
Try messing with the latch where the trunk meets the body, open the trunk and look insude right where the 2 'mate', like the center of the trunk under where the hamburger is, and loosen it, move to the left right, up down, fondle it and you should get it.
Old May 30, 2002 | 09:10 AM
NmexMAX is right - that's exactly what I had to do to mine. You know, fondle it a bit.
Old May 30, 2002 | 09:18 AM
97BlackMax's Avatar
yeah, i have the exact same problem...i hear the "clunk" noise as if it opens, but i have to give it a good yank to get it open...i'll try messing around with it as you guys have said
Old May 30, 2002 | 09:28 AM
Kevin's Avatar
Yes mine does make the clunk that release the latch
Old May 30, 2002 | 09:43 AM
MaximaRider's Avatar
make sure nothing is stuck in the bottom part of the latch, there was a pebble stuck in my mom's 2k1 SE and i had to yank the trunk open and once the pebble was out it went back to normal.
Old May 30, 2002 | 10:00 AM
Good point - check to make sure nothing is jammed in it first.
I looked at mine to refresh my memory. The latch assembly located at the bumper was slightly out of alignment. As stated above, I just had to fondle/finger it back into the correct position. It doesn't take much. Make sure the two screws are tight as well.
Top View
View from trunk
Old May 30, 2002 | 10:26 AM
Kevin's Avatar
Top View
View from trunk
Thanks for the pics. Will look at this tonight!
Kevin
Old May 30, 2002 | 12:18 PM
QuEeNz MaX KiD's Avatar
Top View
View from trunk
ur tha man... that trick worked for me.. thanx
Old May 30, 2002 | 09:22 PM
iregula's Avatar
maybe the trunk lock switch is halfway onl...check inside your trunk
Old May 31, 2002 | 08:17 PM
Kevin's Avatar
WEll I tried this today. Still doesnt worrk. It seems that even when it is free from the latch it still doens't have the "spring" to it are there torsion springs or shocks in the back tha tcan be adjusted? Does the trunk have to be balanced or counterbalenced when you add a spoiler? any ideas folks?
Kevin
Old May 31, 2002 | 11:53 PM
MercerMax's Avatar
I'm under the assumption that most of yawl have GXE's and are talking about the "pull" type lever for the trunk. I've got an SE with the button solenoid type. The remote works fine when used to open the trunk, but the button on the driver's side door has never worked ever since I bought the 95 Max two years ago. I'm pretty sure the switch in the door is bad. It's not the fuse, already tested it. Anybody ever had this problem? Anybody ever replaced that switch in the door? Expensive? Thanks guys.
Mahmuth
Aug 16, 2024 08:23 PM
REDinLV
Aug 15, 2024 12:30 AM
gavin68
Sep 18, 2021 12:36 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
