Honk! Honk! Horn ?
Old Dec 2, 2000 | 11:27 AM
95GreenGLE's Avatar
ok.. my horn doesnt work n my 95gle. the fuses are all fine, the relays are all in, there is power to the fuse in the fuse box, but i think there is a short in the wire from the fusebox under the hood to the horn. anyone know an easy way to replace the wire or to run a new one or anything else i can check? thanks
-Nick
Old Dec 2, 2000 | 04:03 PM
Daniel B. Martin's Avatar
-Nick
A short circuit would have blown a fuse. If your fuses are still good, you don't have a short.
1) Locate the horn relay in relay box #2, just in front of the battery. It is black and smaller than the other relays. Remove the horn relay.
2) Use a meter to verify that relay socket #2 has +12 volts at all times. If it does not, check fuse 64, a 10 amp fuse located in the narrow fuse-and-link box adjacent to the battery.
3) Use a meter to verify that relay socket #1 has continuity to ground when the steering wheel horn switch is pressed, and no connection when not pressed.
If steps 2 and 3 (above) check out, use a jumper wire to momentarily connect relay sockets 2 and 3. The horns should sound. If no sound, there is an open circuit in the green wire which leads from relay socket 3 to the horns, or the horns themselves are bad.
Old Dec 5, 2000 | 08:04 AM
95GreenGLE's Avatar
ok, did that. all 3 of the relay sockets were working as they were supposed to, and i tested the horn and that is good. I patched into the bottom of the relay bok and ran a new wire to the horn (from the socket that only has power when the horn is pressed) and now every time i press the horn the fuse blows, instantly, did i do something wrong again?
Old Dec 5, 2000 | 08:26 AM
If the horn sounded when you used the jumper wire, the existing wire from the relay socket to the horns was good. There was no reason to install a new one.
Before you installed the new wire to the horn you had no blown fuses. Now you do. Something you did has caused a short circuit. Maybe the new wire has a short circuit. Maybe you disturbed something when you patched in to the bottom of the relay box. I guess the next step is to remove that new wire and see what symptoms remain. If you have a buddy who drives a Nissan, test your horn relay by plugging it into his car. I think all recent Nissans use the same relay, so it wouldn't have to be a Maxima.
Old Dec 5, 2000 | 11:02 AM
Maxima97GLE's Avatar
I'm not trying to be a d*** but... did u check to see if the wire to the horn is still plugged in? i found mine popped out once.
Old Dec 5, 2000 | 11:33 AM
95GreenGLE's Avatar
meant...
sorry, i meant to say that everything checked out meaning the one that has the +12v constant checked out, the constant ground checked out, and when i press the wheel, the 3rd socked checked out but when i jump it, there was no noise. so i ran the new wire, and now all i do is blow fuses.
Old Dec 5, 2000 | 12:44 PM
Re: meant...
The "no noise" you observed with the jumper meant
- bad horns
- open circuit between relay socket and horns
Evidently this new wire has caused more harm than good. Please remove it. Let's hope the fuse-blowing problem goes away. Then you can resume troubleshooting.
Old Dec 5, 2000 | 06:57 PM
95GreenGLE's Avatar
horn is good, i checked that out before i ran the wire by hooking it up to the battery (when i touch a wire from the lead on the horn to the battery, it works) , so it wasnt the horn, it was an open circuit between the relay and the horn. but a new wire did not fix it, what do i do now? besides try another relay
Old Dec 5, 2000 | 07:12 PM
Let's accept the premise that you have correctly diagnosed the problem as an open circuit in the wire from the relay to the horn. In that case running a new wire from the horn relay to the horn is the right "fix". Somehow, your first attempt to run the new wire was unsuccessful. Try again, double-checking your work at every stage.
You might connect just one horn, and then the other horn. This isolation might point you to a defective horn, one which has an intermittent internal short circuit.
This is a strange problem and your frustration is understandable. Keep plugging away; you will solve it.
Flores94
Aug 13, 2015 01:17 PM
MaxRX7
Mar 27, 2006 06:16 AM
The_quorum
Dec 8, 2000 06:18 PM
nodoubt711
Nov 16, 2000 08:33 PM
