60K mile service - is power steering/brake fluid flush necessary?
Old Jun 6, 2002 | 11:37 AM
Str8ridin's Avatar
I just went to the dealer to get a quote on the 60k service for my mom's 99 Maxima's 60k service. I plan to do most of it myself -
spark plugs
air/fuel filter change
oil/filter change
throttle body cleaning
coolant flush
and have them do the tranny flush service. However, they insisted that it is necessary to have a power steering and brake fluid flush as well. Is it necessary?
BTW, the total 60K is $535 plus tax.
Old Jun 6, 2002 | 11:52 AM
mango95se's Avatar
Re: 60K mile service - is power steering/brake fluid flush necessary?
I have no idea about power steering fluid flush, but a brake fluid flush isn't a bad idea although not necessary. i didn't do mine until 85k and they've worked fine. That's also a DIY thing. Even easier w/speed bleeders - $20-30 for the speed bleeders and then your brake fluid.
spark plugs
oil/filter change
coolant flush
Old Jun 6, 2002 | 12:22 PM
Jamsan's Avatar
too lazy to search, so anyone have good sites on the DIY 60k tuneup....also, i just changed my fuel filter, and im gonna clean my TB this sunday at the meet, so do you think its necessary to do it again when it comes to 60 k? ...im at 54 k right now
Old Jun 6, 2002 | 01:33 PM
stjohnr's Avatar
$535 is a lot of money. Do yourself a
favor and just do it . It is very easy!
Old Jun 6, 2002 | 03:04 PM
Str8ridin's Avatar
Re: $535 is a lot of money. Do yourself a
I AM doing it myself if you read my post correctly. The thing I am wondering is if power sterring fluid flush $69 and brake fluid flush $79 included in the 60k is worth it and necessary because i do not know how to do those.
Old Jun 6, 2002 | 03:08 PM
mzmtg's Avatar
Minister of Silly Walks
You can probably do the brake flush yourself.
If you are familiar with brake bleeding, you can do the flush. Instead of one or two pumps to bleed the air from the brakes at each wheel, you do about ten pumps at each wheel to completely flush out the old fluid in that line.
As for the PS flush, I wouldnt worry about it. Just keep it topped off.
Old Jun 6, 2002 | 03:10 PM
Str8ridin's Avatar
Thanks bud, finally, something I wanted to hear.
Old Jun 7, 2002 | 10:53 AM
gsleve's Avatar
Yes the power steering fluid is necessary to change the hydraulic fluid gets contaminated over this period of time What you can do is purchase a turkey baster at a stop & shop and suck out as much fluid as you can you may not get all of it then (be mindful of wher the luid livel was before the exchange) and pour in some synthetic atf fluid then start car and turn the steering wheel as far left as possible then turn far right as possible do this about four times to purge any air out of the line if you perform this once a month for the next 3 months all of the fluid would have been flushed out and replaced with new fluid. Reason for this proceedure is it abates the later purchase of a steering rack wich is a great deal of $$$$ around 400-600 for a poperly rebuilt one not including the install, so its up to you $6.00 worth of atf fluid done 3x every 40,000 miles or wait to have the rack replaced.
Old Jun 7, 2002 | 10:58 AM
MaximaPower's Avatar
here u go
http://integra.vtec.net/geeser/megamax/60k_service.html
Old Jun 7, 2002 | 11:08 AM
Jeff92se's Avatar
I'm needing a caw
I do this
http://forums.maxima.org/showthread....essure+bleeder
rbuswell
Nov 17, 2016 04:54 AM
Ray229Harris
Sep 16, 2015 08:16 PM
hydriplex
Aug 28, 2015 02:13 PM
Maxgig
Aug 18, 2015 09:17 PM
