Which ECU pin is pin 1?
Old Jun 10, 2002 | 02:02 PM
xHypex's Avatar
I decided to try tapping directly into the ECU for my shift light, but when I was looking for pin 1 I couldn't find the green/white wire I was looking for. I know pin 1 should be one of the four corners, but can someone tell me which it is? If I was going to guess I would say that pin 1 was probably at the bottom, but I don't know which side it is. Could you also make sure you tell me whether "top right (or whatever" and from which side to look at the ECU connector (from the back, etc.). Colors don't help too much, but if you could give me your colors that would be a start.
-hype
Old Jun 10, 2002 | 02:19 PM
xHypex's Avatar
I just looked at the wires and the colors are (looking at the ECU wires from the back) : Top left (purple/blue), Top Right (red/silver), Bottom Left (Black/Purple), Bottom Right (white/silver)
I've never seen any of those colors mentioned before If someone could help me out I'd really appreciate it. Then I think it's time to invest in a FSM.
-hype
Old Jun 10, 2002 | 06:04 PM
Nismo87SE's Avatar
Wire the shift light to the #1 coil.
-hype
Old Jun 10, 2002 | 08:44 PM
xHypex's Avatar
Thanks for the reply, but that means nothing to me. Which would that be? I don't know the order of any of the pins.
-hype
Old Jun 11, 2002 | 09:56 AM
pocketrocket's Avatar
xHypex
On my 95 ECU, pin #1 does not correspond to a pin on the outer edge.
I'd suggest you check a 99 Service manual, but I'll give you the info from the 95 Service manual.
Looking in to the harness connector (terminal opening, NOT back where you can see the wires):
The general shape is as follows (sorry, it comes up messed up): ___
xxxx xxxx 1xx x | | xxx x xx xxxx xxx x
xxxx xxxx xxxxx x | | xxxxx xx xxxxxxxxxx x
xxxx xxxx xxxx x | | xxxxx xx xxxxxxxxx x
xxxx ___ xx xx xxxxx xxx x
You can copy this and paste it in notepad (it'll look like how it's intended). Looking in to the front of the harness connector (looking at the terminals, not the wires), you will see:
1st bunch (3 rows x 4 columns)
2nd bunch (same as 1st)
3rd bunch, uneven. Three on first row, it's the top left. Wire color on mine is yellow w/ red strip. Mine's a 95
Hope it helps.
Old Jun 11, 2002 | 10:55 AM
xHypex's Avatar
That was a good diagram especially for text Thomas sent me the FSM page, but yours would have helped just as much. I still can't get my shift light to work though Every time I ground the Harlan my tach drops to 0. I guess maybe I should post in the 5th gen forum since my ECU is closer to theirs.
-hype
Old Jun 11, 2002 | 04:55 PM
I saw your other thread on the Harlan shift light. Good luck, hoper you get an answer.
AaronL
Nov 15, 2020 11:52 AM
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
beerman1378
Sep 8, 2015 02:19 PM
