Break Light is ON
Old Jun 10, 2002 | 02:35 PM
mipinc's Avatar
Break Light is ON
The break light on my 95 Maxima is ON for a while now. It came on about 6 month ago when I drove the car cold in a cold night. It went away then it came back again about 2 month ago and since then is stayed ON. The oild level is fine and I don't know if there is anything elase can cause the light to stay on. The breaks are working fine otherwise.
Old Jun 10, 2002 | 04:09 PM
exhip95's Avatar
It sounds like it could be the switch on the E-brake handle or a bad electrical connection at the master cylinder. Check the connections to be sure they are clean. You can also check the switch at the E-brake by disconnecting it and checking for continuity between the pins. There should be continuity when the handle is up.
Old Jun 10, 2002 | 05:06 PM
pocketrocket's Avatar
What are the chances the fluid level switch is sticking? I guess the same chance as the e-brake switch. That's the only two things I can think of too.
Old Jun 10, 2002 | 05:29 PM
mzmtg's Avatar
Minister of Silly Walks
B-R-A-K-E
Old Jun 10, 2002 | 06:36 PM
exhip95's Avatar
Thats good.
It always sucks when the brakes break...or don't brake.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
lowpost99
Sep 8, 2015 05:06 AM
Maxima30
Sep 7, 2015 06:13 PM
