Question on Camber kit
Old Jun 13, 2002 | 02:26 PM
maxima168's Avatar
Is camber kit just 2 bolts? or is there also something else? is it just for the front wheels?
Old Jun 13, 2002 | 03:12 PM
krzymax's Avatar
Maxima owner since 2000
there are two kinds of camber correction kits. the camber bolts which correct up to 1.75 or so and camber plates that correct up to 3. and they are made for the front only
Old Jun 13, 2002 | 07:34 PM
maxima168's Avatar
What is the price ranges for both? Should I get the camber plates instead? Because I do not think it worth paying for two bolts that I can go to any hardware store to get.
Old Jun 13, 2002 | 11:55 PM
krzymax's Avatar
the bolts don't cost much. i don't think they should be more than $60 or so. as for the plates, they're expensive. around $300 or so.
Old Jun 14, 2002 | 12:30 AM
maxima168's Avatar
i think that is alot of money for 4 bolts.
Old Jun 14, 2002 | 06:49 AM
MaxedOut's Avatar
its only 2 bolts..
the eibach ones correct up to -/+1.75 degrees its 32 bux with tax.. i just bought it the other day..
it's the upper bolt for each side... in the front.. the back cant really be aligned
Old Jun 14, 2002 | 08:30 AM
njmaxseltd's Avatar
The reason the bolts are more expensive then your local hardware stores bolts is because of the grade of steel used. And the fact that they have a very odd cut to the shaft making it possible to adjust your camber.
A bolt at your local hardware store is not as strong as the bolts used on suspension components by Auto Mfgrs.
I snapped a bolt on my Honda and the hardware store would not sell me a replacement. He saw the markings on the hex head and told me he could not provide me with a bolt of that stencil strength.
Old Jun 14, 2002 | 02:54 PM
maxima168's Avatar
ok. thanks alot guys.
Old Jun 14, 2002 | 03:40 PM
ru4real's Avatar
I think you meant "tensile strength".
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
pears
Sep 18, 2015 05:25 AM
