Replaced PCV valve wtf!! something fell in
hey i just replace my pcv valve and the lil rubber gaskets between the engine and the valve fell in is that bad? can it mess my engine up. some peeps told me just run it its melt etc. wtf i just got this car and i just wanted to make it run better looks like i made it worse right. now im running my car without the rubber gasket seems fine but i know its in thier HELP!!! and where can i get the gasket nisan dealer???? and $$$$$$$
Re: Replaced PCV valve wtf!! something fell in
with the engine on, make sure u cant feel a leak there..... but seriously, it can't be good for your engine, but damage wise i doubt much will happen...
i just put the pcv valve in thier with out no gasket(moves around) so it does leak. im just hoping it doesn't hurt my engine and will it melt etc. or where would it go in my oil pan and can it blonk something etc. im scared!!!!????
Did it fall into the cumbustion chamber and if it did, Find the spark plug located with the cylinder and take it out and start the car and wait about 5 seconds and shut it off, Whatever is in there should be thrown.
If it's rubber, It should burn up and everything will be ok, I had a metal o-ring from the fuel injector fall in mine and i did this now i'm crusing away.
(It's a bird, It's a plane; No, It's a 99Maxima SE limited)
I would get that grommet out of there... I haven't seen the inside design of the rear bank valve cover. If there isn't a baffle (to keep oil directly away form PCV Valve) separating the PCV valve and the rest underneath... the rubber piece will be amoung the 2 camshafts and all the moving parts associated with it. If there is a baffle/chamber it may just remain there but you still need a new one grommet.
Maybe someone who has seen the inside of the rear bank valve cover can be of more help.
Originally posted by sinewave
Get it out of there! I doubt if it will melt, the temperatures are not that high. Most likely the camshafts will shred it and you will get chunks of it in the oil journals.
You might have to suck it up and pull the rear valve cover to get to it, but oh well...
Same thing happened to me. I couldn't believe that the gasket fell in. I was desperate to get the gasket out. I got a hanger and bent the end to make a small hook then I bent the hanger about 2 inches down to make a 90 degree angle. As soon as I put the hanger through the PCV valve opening I could feel the gasket. It took some work but I was able to move it up to the hole and use a pair of needle nose pliers to pull it out. It was tedious but it solved the problem.
I was able to reuse the gasket. I would recommend putting the valve and gasket in the hole first, then carefully placing the rubber tube connection on top. It's not easy but if you work it enough it will
go on! Don't give up yet!
I hope this helps.
Boo
I hope this helps.
Boo
First look through the hole with a light and see if there's a tiny chance you can still get it out with one of those small-part-grabber-things or stiff wire or something.
If not, you're going to have to pull the cover.
But definitely get it out of there....
-RMB
o NO!!! what about if i do a engine flush would it clean and the lil rubber pieces cause i been driving around with it WTF!!! WHAT ABOUT IF I PUT A SHOP VAC. ON THE HOLE AND TRY TO SUCK IT OUT???? IDEA?!
Boo had a good idea about the coat hanger, but barring that, I think you might have to suck it up and pull the valve cover.
There's some other recent thread where some guy dropped a nail, a frigging steel nail, down his spark plug hole.... Now he's screwed.. At least you can just pull the cover and not the whole head!
If you do pull the covers, make sure you get new gaskets and everything from the dealer..
-RMB
Iregula -- I just put the hanger in about 1" down. I was careful not to push the hanger all the way in the case!
boo
Originally posted by boo
I tried the shop vac but it wasn't enough suction because the vacuum pipe was too big. If you could get a vacuum pipe that fit snug over the hole you may be able to get it to the top and then use pliers to get it out.
boo
boo
ok when i leave work im going to try and take it apart and clean it up how would i clean all the lil pieces of rubber??? and anyone know where to start on removeing the valve cover??? what tools i need cause my tool are in my garage i work at so help me out
ummm.... I'm pretty sure from looking at it that that valve cover would be a nightmare. I'd get a Haynes or Chiltons manual and go over that real well first.... Also pre-order all the gasket's you'll need from a Nissan dealer...
The thing might still be in one piece, hard to say. If it is in little pieces then nothing but time and patience will be your tools(and maybe 100 or so rags, toothpicks and qtips...).... Just remember not to leave pieces of anything else in there....
-RMB
The valve cover is a piece of cake to remove; just 10-12 bolts. It's the upper intake manifold that will take some time. I haven't removed it, but I've heard it takes 3-4 hours.
most of the people in the the garage i work at said just leave it alone etc. what the worse that can happen to my engine????? in the long run??? cause i wanna hook my car up etc. i just order the gromment its 9.00 with my discount reg. 11.95
...what the worse that can happen to my engine????? in the long run???
lol know i don't know how to put it back together wtf!! i have to wait for the valve seal and the gromment to come in their was a rear hose that was a ***** to get off took me about then 2.5hours lol. anyone have any idea or tips that may help me put it back together?????????? but i was lucky it didn't get eating up by the camshafts etc. YAY thanx guys
and what can i clean ( valve cover intake manafold etc). just care and clean stuff anything to look for that could be damgae.thanx while i have the car apart
The rubber gasket for the camshaft cover is the reusable type. I can understand your reluctance to put the old one back in, but if you really need your car, you can reuse it. I used the old gasket on my front one when I polished it 3 years ago, and I don't have any leaks.
As far as putting it back together, I don't know exactly what to say except that you put it back the way you took it apart.
it looked like it was all bent and melted i'll just put a new one i heard they only sell in pairs in so i don't have to worry about this thing happen again thanx tho what about the intake gasket is can i reuse it
lol i don't feel like putting it back together lol i have to work on it when i get home i have to order the gaskets i need valve gasket and the gasket on the screws and the intake gasket manifold right????
how do i clean my manifold with crab cleaner???? cause it looks kinda dirty
lowpost99
22
Sep 2, 2015 04:38 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
i'll just change the oil with in 1,000 before the due day
