Hesitation/lag on 5spd
Got a 96 SE 5sp and for the last several thousand miles, I have a about a split second delay just after I shift where the car seems to be choking. This lag seems to happen more in 3rd and 4th gear than the other gears. But its definitely intermittent and ofcourse magnified with the A/C on. I have just cleaned my throttle body, it was nasty. It didn't seem to help. I am about to change my fuel filter too, although I don't think this will help either. Oil is changed every 3k and I have a K&N filter. The car hasn't seen octane below 92 ever...Otherwise my car is in tip top. Anyone have any ideas or experience the same problem in their 5speeds?
Thanks to this site and Maximadriver.com, I have put clear bumpers on(like night and day) and my hybrid intake is coming and also my Budget y-pipe. I should have them on this weekend.
Re: Hesitation/lag on 5spd
Ohhhhhh yes it will
The feul filter is supposed to be changed every 15K miles. It is a very ofetn neglected maintenance item. I bet your feul filter is the original one that came on the car from factory.
You may want to step up to a 300ZX feul filter. It's twice the size. I have it on mine. It won't boost performance, just double the change interval to 30K miles.
DW
DW
Originally posted by ATLMax
. . I am about to change my fuel filter too, although I don't think this will help either . . .
Re: Re: Hesitation/lag on 5spd
I changed my fuel filter at 50k and I have 90k now. I guess its time to change again. Actually I had this problem back at 50k and changing my filter didn't fix it...
Originally posted by dwapenyi
Ohhhhhh yes it will
DW
Ohhhhhh yes it will
DW
It may be bad plugs...alot of guys change theres on the .org and say they feel a big difference..you wont feel anything over stock, it will just bring the stock power that was once there, back
-matt
I think I need new ones soon too
-matt
I think I know exactly what you're talking about, and changing fuel filter and doing tune up won't help at all.
The hesitation during shifts I think is just how the manual tranny is on our cars. The car seems to bog down a little before the gear fully engages. I've noticed it both on my 98 SE and on my friends 95 GXE. It's pretty annoying during quick shifts, but it doesnt happen all the time. Like you said, it seems to happen mostly during the 3rd to 4th gear change.
Thinking about it a little more, I've noticed my car started doing that recently. I thought it had to do with my recently installed ACT clutch. The ACT is a storng clutch, but it ain't the smoothest. I was starting to think that the bogging that occurs is b/c the ACT engages the gears so abruptly sometimes. Never happened with my stock clutch. Are you guys all running aftermarket clutches?
DW
DW
Seems like a common intermittent problem. I have a stock clutch still. I hope when I put my new intake in, it will help.
DW
DW
DW
What do you mean by the ACT being "not the smoothest?" I have 600 miles on mine and its alot smoother then when I first got it but its still roufe when I engade 1st and Reverse...IM HOPEING it goes away soon..alot of guys say it goes away fully after 1000K Miles...
-matt
Oh and the hesitation your talking about, I have that too..I thaught it was my slave cylinder that wasnt realaced when I did the clutch...
-matt
Re: DW
The ACT clutch gets easier as you break it in, but it never becomes like stock. With the ACT, when egaging gears, there's a point where the clutch just starts to grab and the point wehre the clutch is fully engaged. The distance between the 2 is very small, so it's harder to engage smoothly. You can do it, but it is more effort than the stock clutch. I am mostly used to it now. If I let a frined drive my car, stall city all the time. I keep warning them that my clutch is tight, and they realize just how much
With the stock Nissan clutch, the grab and fully engaged area of play was much wider. A little too wide. The stock clutch was weaker, but smoother, too.
DW
DW
-matt
-matt
Where in ATL are you? hopefuly ATL means ATLanta.. otherwise sorry to be a PW on this thread
I have 600 miles and the clutch like grindes when I engage 1st and reverse...its like a chatter
-matt
-matt
As for the hesitation issue; my car occassionally has similar symptoms. It's all most like the car is flooding for a moment - it's probably from the extra gas that is being dumped in at the higher rpm lingering around a little bit when the rpms drop so suddenly
For you 5 speeds - if I take off in first slowly, meaining the clutch is out but I'm casually driving, if I stomp on the gas at around 4 or 5k rpm the car doesn't spin the tires, it seems like either the clutch slips or the tires are spinning but aren't making any noise. I doubt the clutch is slipping since it chirps 4 of the gears, and is a fairly new ACT, but I don't have any tire squeal on these occassions. DO you experience this? Is it that the engine spools up so quick so it sounds like I should be spinning? I can't explain what I'm talking about but thanks for reading this far.
sure does, i live in buckhead near lenox/phipps. my budget y-pipe shipped today and my intake arrives hopefully tommorrow...
Originally posted by spiff56747
If I floor it in first, anywhere above 3k rpm, the tires will squeal. I have the stock clutch. My tires sometimes don't squeal if i just do a burnout from stop, but I can still smell them burning (I hope its the tires) so I guess Kumhos sometimes dont screech when they are laying down rubber.
It all depends on your tires if you get squeal through first..my buddy only has an intake and 5spd and he get sqeal all the way through 1st..I have my 17's, CAI, ACT, and Y-pipe and I dont, But i can also chirp third and he cant :P
-matt
-matt
I tried this on the way home from work today. I stomped on the gas in 1st around 3500rpm and it took off but no squeal at all. Do you guys have intake mod and y-pipe? I just got my hybrid intake and budget y-pipe today. I'm hoping to get some new squealing.
