please help my max got issues!!
Old Jun 22, 2002 | 08:23 PM
AuToMaX_95's Avatar
in the morning when i stop at a sigal light waitting and when it turn green, i step on the gas pedal,usually should go up to 20mph and it didn't go fast until 2 or maybe 3 second later.. can any one help me i have no idea whats going on, it never happne like this before and at first i thought it was maybe time to change oil and after i went to change oil, it got a little better but after 30 mints later it happen again, ... please i need helpppp!!!! also does any one know where i can get some fatory paint for my 95 pearl white max.. ?? cheaper the better
Old Jun 22, 2002 | 09:11 PM
95emeraldgxe's Avatar
it might have been stuck in a higher gear.
Old Jun 22, 2002 | 09:27 PM
AuToMaX_95's Avatar
but then my car is a auto.. and i put it on Drive... I don't think my transmaition is mess up.. anyhow i have no clue what is wrong with it..
Old Jun 22, 2002 | 09:35 PM
1slowmax's Avatar
Try changing your tranny fluid.
Old Jun 22, 2002 | 09:46 PM
97GLE's Avatar
Agreed, if your car runs fine, but bogs randomly, then the first thing I'd check is that autotragic tranny. Go get the fluid flushed, I think its about $90 at Nissan and about $60 at your neiborhood lube place.
Old Jun 22, 2002 | 10:06 PM
pocketrocket's Avatar
Re: please help my max got issues!!
AuToMaX_95
Just to clarify, if you did not come to a COMPLETE stop, you will not drop to 1st, so it will feel bogged down and sluggish. Crawling will still keep you in 2nd gear.
Pearl white is a bit*h to touch up, the paint process is very complicated because of the different layers involved (base, pearl, etc). Cheaper is not an option, try www.paintscratch.com
Old Jun 22, 2002 | 10:09 PM
iansw's Avatar
This is way out there, but watch your OD light when it does that. The OD has a safety feature that will stick the car in 3rd gear when it has problems.
Buy a Haynes Manual, and it shows you how to troubleshoot the transmission using the OD light to spit out diagnostics codes.
IanS
Old Jun 23, 2002 | 09:44 AM
AuToMaX_95's Avatar
thanks for all your helps
first im gonne with 1slowmax and 97GLE and go get a fluid fluished.. and then see what happens.
oh btw pocketrocket.. i was at a completely stop and it that thing still happened... so i guess now the only thing i can do is go get a tranny fluid change then i'll let you guys know what happen.
Old Jun 23, 2002 | 09:51 AM
AuToMaX_95's Avatar
Re: thanks for all your helps
btw how often are you suppose to change tranny fluid?
Old Jun 23, 2002 | 10:48 AM
AuToMaX_95's Avatar
Re: Re: please help my max got issues!!
Originally posted by pocketrocket
AuToMaX_95
thanks for the web site .. but do you know if they match up the paint good? have you ever order from them?
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
Hailstatejig
Sep 2, 2015 06:52 AM
