Corner Bulb No Brght like my Headlights
Old Jun 23, 2002 | 12:21 AM
MAXXspeed18's Avatar
I just bouhght a pair of Xenon bulbs (1157) for the corners, i wuz thinkin that they'd be bright like sum of the maximas i see on his site (bright as the headlight).....they still came out dim, not much different from the stock bulbs......my question is...what do i have to do to make them bright like my headlights,do i have to rewire them, or do i jus needbetter bulbs?
Old Jun 23, 2002 | 01:25 AM
spiff56747's Avatar
I think if you just put the bulb in backwards, IE rotated 180 degrees, it should light up much brighter than before. You might have to clip off the little nub on the metal part of the bulb, the one thats closer to the glass.
Old Jun 23, 2002 | 04:04 AM
njmaxseltd's Avatar
The 1157 bulb will only go in the socket one way because of the offset the 2 nubs have. Pay attention to which way it goes in then do the following:
Grab a nail clipper and snip the nub closest to the bulb off.
Put the bulb back in the socket 180 degrees from how it's supposed to go. Then enjoy your bright lights!
Old Jun 23, 2002 | 08:35 AM
gepetto's Avatar
if you're having trouble, cut a strip of electrical tape about 2 inches long and 1/4 inch high. wrap the tape around the spot where the nub used to be, but dont cover up the bottom nub. now look down into the bulb socket. you can see that there are two grooves: one designed for the higher nub, one designed for the lower. heres the trick: you want the lower nub to go in the spot for the higher one. place it in and turn it so that it locks. replace housing and the clearance lights are going to be brighter! hope htis helps!
Old Jun 23, 2002 | 10:13 AM
chigga's Avatar
good **** yall i was thinkin bout doin this lil mod too, except the other people made it seem more complicated than that....
damn i just did it, theres a ill difference. even my pops was like damn. good **** yall!!!!
Old Jun 23, 2002 | 02:23 PM
Requin6's Avatar
can i find these nice 1157's at a local parts store...or are they mostly mail order?
Old Jun 23, 2002 | 05:45 PM
Krash513's Avatar
I just read this post and id give it a whirl, it took me 2 minutes and DAMN what a difference!!!!!
Old Jun 23, 2002 | 05:51 PM
Unibomber's Avatar
http://unibomber.netfirms.com
look here for a how too
Old Jun 23, 2002 | 06:33 PM
chigga's Avatar
to answer ur question, yeah u can get em from an aftermarket car shop, no problem to get. try installin them the regular way then do this lil mod to really appreciate it.......
Old Jun 23, 2002 | 10:52 PM
thanx alot for the lil mod on makingthe brighter, i just did the today and they came out bright as hell, i hope i jus don't get no cop thats being a real jerk pull me over
Old Jun 23, 2002 | 10:55 PM
matty's Avatar
will this work on a 96 ??
-matt
Old Jun 24, 2002 | 05:44 PM
Unibomber's Avatar
i think so i think it was 95 and under that used BOTH fillaments on the bulb
ie when u turned your signal on the cornerlight would light up
try it anyways bulbs are like 3 bucks
Old Jun 24, 2002 | 07:10 PM
marc98se5's Avatar
Here is another option for you:
http://web2.airmail.net/scutchen/max....htm#97corners
It is easy to do and can be done in about 1/2 an hour.
Or check out the MaxFAQs at
http://web2.airmail.net/scutchen/max_faq/
Old Jun 24, 2002 | 08:38 PM
96BLUMAX's Avatar
95/96 is really easy. All you do is take the two power wires(ones that aren't black) and splice them together so that the voltage is the same all the time. Very easy and works the same.
Old Jun 24, 2002 | 10:47 PM
MaxEffect414's Avatar
Hey i just did the mod where you shave off the thing on the bulb and everything was going great and i was like damn what a difference and then everything just turned off.
Even my fog lights went off and they won't turn on, the head lights will but not the corners or fogs and i checked the fuse and relays and bulbs and nothing seems to be wrong, Did i miss something????
Is there anything else i can do???
Please help!!!!!!!!
Old Jun 25, 2002 | 03:32 AM
black019's Avatar
wow, talk about something that has been discussed millions of times...
Old Jun 25, 2002 | 07:06 AM
Ramse's Avatar
Man those things are BRIGHT!! Just tried it and it's daylight out here. Can just see the headlights but my corners are BEAMIN'! Did it the way it said on http://unibomber.netfirms.com/ and left a piece of the top one on so it kinda holds it a bit more.
Old Jun 25, 2002 | 07:14 AM
JacksMax's Avatar
If only you new guys KNEW how many 100s of 1000s of times this has been discussed here in the last few years.
Now, do you want to make the rear windows go down all the way? Ask me REALLY REALLY nice and I might tell ya!
Old Jun 25, 2002 | 08:19 AM
Please help!!!!!!!!
Old Jun 26, 2002 | 07:15 AM
BajaPanty_96SE's Avatar
I agree totally that all users should at least try and use the search option but what is the point of having a forum where you get to interact with other people about similar problems?? In case you haven't noticed I'm still considered a "newbie" even though I've been with the org for 8 months. I guess I'll always be a newbie if all I ever do is use the search option. I wish I had something to contribute to the org but most of the members have seen and done it all....so all us newbies can do is search. Sorry I just had to vent a little bit.
Old Jun 26, 2002 | 07:34 AM
JacksMax's Avatar
Welp, *I* can make *my* rear windows go down all the way, can *you*???
Old Jun 26, 2002 | 10:17 AM
Found the problem, the damn fuse blew, I put a 10Amp fuse now it works.
Old Jun 26, 2002 | 10:27 AM
JacksMax's Avatar
Hey, I thought you said you checked the fuses???
Old Jun 26, 2002 | 03:02 PM
I did but i failed to check the tail light fuse, I didn't think it was related to this problem but i guess it was.
Plus the fogs didn't come on because there rewired into the parking lights.
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
