biggest tire on a 7" wheel?
![](https://maxima.org/forums/images/smilies/support.gif)
Re: biggest tire on a 7" wheel?
Originally posted by Purs
can I put a 235/45-17 on a 7" wheel? thanks.
so how much smaller is a 225/50-17 than a 235/45-17? thanks for the quick response.
The diameter from top to bottom of tire will be the same. The width is what is different. If I remember correctly with my tires, potenza Re950's, it went from 8.5" with the 225 to 9" with the 235. Don't quote me on that. Go to TireRack website and look at the techinical info on the tires you are considering, they will give you all the numbers you need for every size tire. I had the same dilema because I found a set of rims I wanted but they only had 17"x7" and I wanted to run 235/45 R17. In the end I waited and found 7.5" and ran the tires I wanted. Again, some people will tell you it's just fine to run that size tire on a 7" rim. Not me.
Recommended minimum size for 235/45 17 for AVS Sports are 7.5 in.
Tire
Size UTQG Rim
Width
Meas.
(Inches) Rim
Width
Appr.
(Inches) Inflated
Dimensions
Overall
Width
(Inches) Inflated
Dimensions
Overall
Diameter
(Inches) Tread
Width
(Inches) Loaded
Dimensions
Tread
Depth
(1/32Inches) Loaded
Dimensions
Static
Radius
(Inches) Rev/
Mile Max Load
@ Cold
Inflation
Pressure
(Lbs@psi)
235/45ZR17 93W 180/AA/A 8.0 7.5 - 9.0 9.4 25.2 8.3 10 11.7 824 1433@51
Tire
Size UTQG Rim
Width
Meas.
(Inches) Rim
Width
Appr.
(Inches) Inflated
Dimensions
Overall
Width
(Inches) Inflated
Dimensions
Overall
Diameter
(Inches) Tread
Width
(Inches) Loaded
Dimensions
Tread
Depth
(1/32Inches) Loaded
Dimensions
Static
Radius
(Inches) Rev/
Mile Max Load
@ Cold
Inflation
Pressure
(Lbs@psi)
