ECU Problem Please Help
I tried to diagnose my car today. I have a 99 SE-L and my check engine light went on three days ago. I have reseted the ECU with a catalyst problem code. Today the light went on again. I tried to diagnose about fifty times but the light refuses to blink. I can't get it to turn off or find out what the code is. Is my ECU bad? Has this happened to anybody else? All help is appreciated. I tried search and couldn't find anything.
Re: ECU Problem Please Help
hm.....cant really help, and dont remember reading anythin about this problem, all i can really say, is to follow the steps real slowly....
Re: Re: ECU Problem Please Help
do you have an automatic or manual transmission ?
Originally posted by DaddyMac
the ECU light doesn't blink or the CEL light doesn't blink ?
Re: Re: Re: ECU Problem Please Help
Manual and the light doesn't blink. I tried to reset many times and it just doesn't work!
Is your CEL light on when the car is running, indicating a problem exists?
Are you sure your actually turning the screw?? Might sound stupid, but it's in a tight spot and could be hard to see and feel. If all else fails you'll have to go to your dealer or a shop near you that can hook up a scan tool and tell you whats wrong.
You can also disconnect the battery overnight. That should reset it.
Re: Re: Re: Re: ECU Problem Please Help
Originally posted by njmaxseltd
If you reset it, then there are no codes to blink. Oh wait, 0505 should blink if everything is ok.. hummmm
Does light in instrument cluster work?
When the engine is not running and you turn on the ignition without starting the car does the CEL come on?
I have a "99 SE and the CEL does not light. It is not the bulb in my Max. I had my mechanic trouble shoot it after I had checked the bulb myself and my mechanic said my problem is with the ECU. Since my Max is running great I have just continued to drive it because to get a replacement ECU from a salvage yard was $250 without any guarantee.
Re: Does light in instrument cluster work?
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
