How long to install ES Endlink Bushings and are they supposed to come with grease???
Old Jun 25, 2002 | 04:07 PM
Kevin's Avatar
Is it a few hour job or do I have to take the suspension apart completely? I just got mine today and I'm itching to try it, but I don't have that much time to do it. Also I don't have jack stands so I'll have to do it one side at a time.
One more thing, was I ripped off? I got the bushings, but I didn't get any grease with them. I ordered from Courtesy Nissan. I wrote to them regarding the grease they said that
"End link bushings are graphite injected urethane.
No grease comes with it."
Is this correct??
Kevin
Old Jun 25, 2002 | 06:18 PM
Kevin's Avatar
Bump..please hjelp me out if you can. Thanks
Old Jun 26, 2002 | 07:26 AM
Kevin's Avatar
Bump
Old Jun 26, 2002 | 10:34 AM
Nealoc187's Avatar
SLOW
I was about to post this same question... I've had mine sitting here for a month and haven't installed them. Mine came with no grease either, though I have silicone brake grease.
Old Jun 26, 2002 | 12:10 PM
njmaxseltd's Avatar
You should have just asked the suspension guru, me of course!
You don't need grease.
The bushings take 5 minutes to install. (If your doing this while your doing your suspension that is....) One nut comes off the top of both end link assemblies, 10mm nut. Then you lift the sway bar up from both sides (left and right) and the bushings slide off the end link assembly. Remember you have to do both sides at the same time or the sway bar will fight you. In other words, you can't lift just the left or right side up because your then trying to twist the bar!
Assembly is of course the reverse order.
Old Jun 26, 2002 | 12:22 PM
Kevin's Avatar
Mr. Guru, thanks for the info! You think I should just wait until we do my suspension? I'm kinda itching to try this out but I guess I could wait to make it easier.
Kevin
PS- how do you like the B&G's?
Old Jun 26, 2002 | 12:40 PM
njmaxseltd's Avatar
Kevin
Absolutely LOVE the B&G + AGX setup. They settled in so nicely. You think my car rode nice when I took you for a ride?? You should check it out now.
Wait for the whole suspension install, you'll never really feel them if you install just them at this point. We'll do the whole job at once. It's much easier that way anyhow.
Matt93SE
May 24, 2019 02:58 PM
kingw323
20
Oct 21, 2015 08:36 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
FlaMark
Aug 20, 2015 12:17 PM
00 Max
Aug 4, 2015 07:09 PM
