toyo proxes a05
they dont have those tires on www.tirerack.com
Re: toyo proxes a05
Originally posted by Ralph Wigum
anyone know where i can get this tire? one of my tires has a bubble on the sidewall and i need to replace it. i went to the dealer and they wanted $190 for it. i was like hell no! any suggestions?
That said, any time you replace tires, you want the tread-depth (i.e. wear) to be comparable on both sides so that the grip is not mismatched.
Re: Re: toyo proxes a05
Originally posted by StygianMax
The spare tire (at least mine) is wrapped with an A05. You should check out your spare.
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
Re: Re: Re: toyo proxes a05
Originally posted by WizzaMax
You have a full size spare in your trunk stock?...I thought they were all donuts...you know the dinky replacements...that is what I have on my 99.
Guess that was a bennie of having the CAN model...evrything else seems to cost you guys an arm and a leg so you got a good item it seems.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Re: Re: Re: Re: toyo proxes a05
Yeah, I have a full sized tire. It's good & bad. Good when I need it but bad in that it's more weight than a donut. btw, my Max is a '97.
Re: Re: Re: Re: Re: toyo proxes a05
Originally posted by Sin
Oh c'mon!!! What's the weight difference between a full size spare and a space saver spare? 25 pounds at the VERY most. Do you think there will be any measurable gains or losses on a 3000-3100 lbs car when you add or take away 25 lbs?
Re: Re: Re: Re: Re: Re: toyo proxes a05
Chill bud. I'm just pointing out the pros/cons. To answer your question in short, no, it makes no discernable difference to me.
