Windshield wiper water pump not working
Old Jun 30, 2002 | 05:18 PM
Thaxxx's Avatar
I have done several searches about this but only have found problems with the wipers themselfs. I have a problem with my wiper washer. 96GXE I filled the tank on it and it won't work. I hear no pump sound when I try to get water. I checked all of the fuse locations that I know of, but none are marked wiper pump etc. Can anyone please tell me where to begin looking?
Mike
Old Jul 1, 2002 | 11:09 AM
Thaxxx's Avatar
anyone?
Bump
Anyone please?
Old Jul 1, 2002 | 11:13 AM
party_boy's Avatar
The windshield water pump is IN tank
so dont let the water level drop too low. Also check the lines (runs in the liner) to make sure that they are not kinked. If anything replace the wiper in tank motor.
Old Jul 1, 2002 | 12:48 PM
Lime's Avatar
check all the hoses...is any fluid coming out anywhere else? You say you hear no pump noise, so, chances are it's toasted. Contact your dealership, I guess.
Old Jul 1, 2002 | 01:30 PM
MaximaPower's Avatar
make sure nothing's cloggin the nozzles...i also have a problem with my washer fluid..i fill it up and it disappears...no trace of leaks or anything...same with my bro's i30
Old Jul 1, 2002 | 10:03 PM
syc's Avatar
syc
the problem might be electrical. the chances of your pump is dead is smaller.
check all connections. and make sure all wires are connected to the washer motor. there might be some loose connection. I had this problem for my other car. (I do not know where the motor is in maxima)
if still don't know what's wrong, try get the motor from the junk yard and install it and see if it work (hopefully cost you less than $10). it should be simple, but I've never try on my maxima nor any car. I just kinda look at my old 240SX's motor and THINK is simple.
if above don't work, should be the electrical problem that's not easily checked. anyhow, look at your haynes in autozone for free, and see if you can figure out the diagram at the end of the book.
as far as the fuse, it is fuse 20 for both wiper motor and washer motor (if you have the haynes manual). but I think you check all your fuse.
never take it to the dealer unless you really have to. dealer just gonna charge your credit card. take your time cuz it's only the washer.
Old Jul 1, 2002 | 10:49 PM
nadir_s's Avatar
vicodin ... gift of life
I have same problem on my old celica. I hear the pump motor running but no water!
I'm guessing the hose is clogged.... bent... broken somewhere... but since the car is so old, i just gave up lol
Old Jul 1, 2002 | 10:58 PM
StygianMax's Avatar
The previous owner of my Max had the car sprayed with oil (undercoating for protection agaist salt & crap) for Canadian winters. The oil was oversprayed & deteriorated the washer fluid lines. I basically had a line leak somewhere (that I couldn't find) & needed all the lines swapped out. It cost $8 worth of materials but about $78 of labour!!! I watched the mechanic do some of the work in changing out the lines. He had to take apart the right fender liner amongst other stuff. The job looked like a real PITA.
Old Jul 2, 2002 | 06:30 AM
Mishmosh's Avatar
Re: Windshield wiper water pump not working
I just did this a few weeks back...
http://forums.maxima.org/showthread....ht=washer+pump
jerrod99_se-l
Aug 27, 2015 08:27 PM
Alberto10mg
Aug 25, 2015 12:54 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
