Changing Atf Soon, Needs Help........
Old Jul 1, 2002 | 09:10 PM
spam7788's Avatar
Planning on changing my ATF soon, and thinking using Redline. Should I just drain the fluid and fill it up with i think 3 qt($30).... If i do the transmission flush that will cost me $80 + maybe 8qts ($80).... is it really worth $160 to flush all the old stuff out?? or should I just do the drain and fill more often with redline???? pls hlep....
Also is it easy to change my own ATF fluid?? what size wrench do it need???
Old Jul 2, 2002 | 02:50 AM
karguy's Avatar
Re: Changing Atf Soon, Needs Help........
I just did step 1 of a 4 step process to convert 97 Maxima to Amsoil
ATF. I elected not to get flush by dealer but drain and refill 4 times allowing a week between steps to let new ATF mix. This should get me to a 93% ratio of synthetic to dino ATF. I've have just finished step 1 last Sunday. It is super easy and takes a 19mm socket. By the way there are 23 bolts on the tranny pan. Can you tell what I was doing while the tranny drained? The results have exceeded all my expectations with only step 1 complete. I would have been happy with the results I got if it took all 4 steps. On the last step I plan on dropping the tranny pan and cleaning it and magnets with cleaner (probably throttle bowl). Based on my initial results I definitely made the right decision. I am not familiar with Redline products but a lot of forum members swear by them. My only recommendation is to definitely go with synthetic ATF. By letting tranny drain real well I got out 5 qts & 2 ounces of ATF replaced with same amount of AMSOIL ATF. I figure it will take 20 quarts total. I took old ATF to Advance Auto for recycling. I got a super deal from a forum member, I got 2 10 quart containers of AMSOIL ATF for $85 with no shipping charge. I live near him. To net it out I would definitely do it, since my car was flushed by dealer only 16,000 ago I chose not to flush. I'll continue to post updates as I progress through steps 2, 3 and 4.
Old Jul 2, 2002 | 04:26 AM
Jime's Avatar
Well I chose to flush mine myself by disconnecting the outlet from the trans to the cooler and pumping out 2 litres at a time and refilling, of course after I drained and refilled the sump. It takes almost 10 litres before it becomes clear but does not mix dino and synthetic and its all done at once.
I just didn't want to mix my expensive synthetic with that dino stuff and the complete change is pretty easy to do.
Jim
PS Its also a great time to put on a trans cooler and do it all at once.
Old Jul 2, 2002 | 05:47 AM
karguy's Avatar
Jim
If you do it Jime's way you'll save ten quarts of Synthetic ATF which will more than pay for a tranny cooler. Sounds like a win win to me. If I had to start over again I would use Jime's procedure.
Be well!!!!
Old Jul 2, 2002 | 07:17 AM
Cumalot's Avatar
I wondering if I just recently have the transmission fluid flushed, but used regular ATF, is it a good idea if I want to switch to synthetic to have it flush again and then put the synthetic in? If bring my own synthetic ATF to a place like Jiffy Lube, you think they will flush and put in the synthetic fluid that I bring?
So if I do that, flush out the old ATF fluid, and then refill with synthetic ATF, how many quarts do I need again? Thanks.
Old Jul 2, 2002 | 07:36 AM
Cumalot's Avatar
Btw, which Redline ATF is it? There's a Redline D4 ATF and a Redline Synthetic ATF.
Old Jul 2, 2002 | 07:40 AM
iwannabmw's Avatar
For everyone who insists on Redline, it's the D4
Old Jul 2, 2002 | 09:13 AM
Jime's Avatar
The system holds 10 qts but you will have to supply a lot more than that to get flushed at a place like Jiffy Lube. Not sure on this but I have heard from 15-18 quarts because of the amount in their system and lines.
Its pretty easy to do yourself and takes a lot less ATF vs Jiffy Lube.
Old Jul 2, 2002 | 05:02 PM
Cumalot's Avatar
Yeah seem like a doable DIY job. When it's time for me to do it, I'll be sure to contact you and get some help, if you don't mind that is.
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
jds22
Sep 29, 2015 02:03 PM
Noela
Sep 26, 2015 08:22 AM
