Please help, is the ECU dead?
Long story made short, i have a SC 95 max. Been having starting problems, changed the battery and the problem wasn't solved, I then attempted to change teh 140A battery fuse and in the process, while disconnecting the battery terminals dropped the wrench somehow, and a spark of electricity ensued, now, I do not have any electrical response at all, does this mean the ECU is dead or something is wrong with the wiring? There is no kind of Electrical response whatsoever, trunk doesn't open, nothing, thanks.
Re: Please help, is the ECU dead?
Re: Re: Please help, is the ECU dead?
Originally posted by cbr2
It is not the ECU that is keeping you from having power.. Does your battery have power??? If so attach a jumper wires from the negative lead of the battery to your engine.. Do you have power now?? If not then your pos. wire died somewhere.. I think there is a big fuse for the whole system.. (not sure but BMW has one) it is probably that.
Re: Re: Re: Please help, is the ECU dead?
ok... Take your jumper cables... Connect only the negative one to the battery.. then connect the other end of the wire to the engine... The engine is grounded just like the battery is so you will in effect bypass one of the wires off the battery..
Re: Re: Re: Re: Please help, is the ECU dead?
Re: Re: Re: Re: Re: Please help, is the ECU dead?
Sorry to be ignorant, but where in the engine do I connect the other negative electrode, how would this give it power? Thanks
I think he means, just to touch any metal part of the engine. And it wont give the engine any power at all, it will make sure like that the wires are good or sumtin....
Originally posted by Toolrocks
I've read this thread to this point, what was it?
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
QueensMAX
09-15-2015 04:14 AM
markevans999
09-10-2015 04:29 PM
