RPM Fluctuating
Old May 3, 2008 | 09:16 AM
bluebriscoe's Avatar
RPM Fluctuating
Today as I was checking my car I found out that between 1k and 2k rpms it moves up and down at a steady pace but only in park or neutral.I have a SEL code P0420 would this cause the rpms to go up and down or is it something else?
Old May 3, 2008 | 09:17 AM
sorry wrong section.
Old May 3, 2008 | 11:10 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
how much you want for rpm fluctuator????
Old May 3, 2008 | 01:55 PM
AnDyMaN's Avatar
i got one for sale, ygpm!!
Old May 3, 2008 | 06:26 PM
Jess's Avatar
SHIFT_In2D
IBFL
Sounds like a MAF problem. If you have a 2000 to 2001 this is usually the case. 02 and 03 it's also possible. If you know anyone with a Max of the same year ask to test your car with their MAF...if the RPMs are steady with theirs then that is your answer.
If it turns out to be that then send a PM to DAVEB he will hook you up
OH and!
Check your air filter first to see if that is the culprit sometimes the simplest thing is overlooked.
EDIT: Just read what the code means it can be a few things...Most to do with the air fuel ratio. Also hope you are running premium...low grade fuels will also trigger a SEL.
Cat Converter
Exhaust Leak
Pre-Cat
O2 sensors
MAF
Old May 3, 2008 | 08:32 PM
rroderiques77's Avatar
Demodded and Forgotten
May also be bad coils. Is the SEL flashing continously? MISFIRE??
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
jchronis2552
Sep 21, 2015 05:52 AM
