Clutch TSB
Old Oct 1, 2002 | 10:48 AM
  #41
Dany's Avatar
Re: Re: Re: Clutch TSB
Originally posted by Afty
www.altimas.net/tsb
Scroll down to "NTB02-084 - 2002 Altima & Maxima: Howl noise when clutch is released." Now you can print out the TSB and bring it to the dealer.
Nice I will try to do that.
Thanks.
Old Oct 1, 2002 | 10:52 AM
  #42
Kojiro_FtT's Avatar
www.altimas.net/tsb
Awesome! Thanks.
Old Oct 2, 2002 | 05:59 AM
  #43
ABS's Avatar
ABS
www.altimas.net/tsb
Afty,
Thanks for posting this link. I think I just figured out the problem I've been having with my car . . . I bet the dealer didn't "align" the flywheel with the crankshaft by using the "dowel" described in the TSB documentation when he did the install . . .
A word of advise to anyone getting their clutch and flywheel replaced under warranty: 1. Make sure your flywheel comes WITH the signal plate already installed, 2. Make sure the tech installs the flywheel by using a "dowel" to line it up properly with the hole in the crankshaft.
I am trying to determine if the flywheel is available without the signal plate for the crankshaft sensor or not.
Old Oct 2, 2002 | 07:20 AM
  #44
Dany's Avatar
Re: Re: Re: Re: Clutch TSB
That is what I am afraid of, getting that Clutch TSB done and when having other problems. Cause Nissan techs will sure mess something up.
Old Oct 28, 2002 | 04:51 PM
  #45
Pangburn's Avatar
Donating Member
Clutch Disk TSB
Has anyone had the clutch disk TSB (NTB02-084) done? My 6-spd just started making the howling noise a few weeks ago but it doesn't seem to affect anything else. Does anyone know if this is just an inconvenience thing or does this noise indicate a longevity issue with the clutch? I'm afraid to crack open the tranny unless it's necessary.
Annoyed but not desparete to fix...
Old Oct 28, 2002 | 05:36 PM
  #46
dblrr900's Avatar
Originally posted by Newman
is this dying squirrel sound like gears grinding? kind of like a "reeeeeeeeeer" for a lack of a better description?
Newman - it is a low squeel that starts when you ride the clutch out on a hill or backing into drivieways. I dealt with this back in March. IF you (or anyone else in VA) get this, take it to Passport Nissan in Alexandria. Talk to Scott in service. he knows exactly what the issue is. He had to change mine out twice.
Good luck.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
