%th Gen 5speed problem
Old Sep 5, 2000 | 07:25 PM
Stranger808's Avatar
I have had my 5th gen sence late June when about 4 weeks and 4000 miles into it my clutch went out.
I took it into te shop and they tried to clame I was abusing it but I have only sed te vehicle to comute to work about 200 miles a day.
Well after further diagnoses they found that the input shaft was warped and had cracked the bell housing and trashed 2nd thru 5th gears as well as toasting the flywheel and clutch assembly.
I know it is a long shot but has anyone else seen this sort of issue.
the car is a bone stock SE by the way
Old Sep 5, 2000 | 09:34 PM
TimW's Avatar
The silent but deadly Moderator
wow... thats a new one...
That sounds really bizarre. Good luck! BTW, I cant think of the name of the law, but everything is covered for the first year or 12,000 miles as I have heard. everything. even wear and abuse are generally covered. Given that, they have to prove abuse, not the other way around. during this time the burden of proof is them. Unfortunately that can make for an expensive time consuming ordeal (ie you still have to pay for the repair, then sue), you should still be ok even if they press the abuse thing.
Old Sep 5, 2000 | 09:40 PM
mhgsx's Avatar
Did you notice any clutch chatter when easing into 1 st gear??
Mine does this, but I attributed this to the previous test drives by morons who don't know how to drive well.
Although, the chatter is starting to disappear.
Old Sep 6, 2000 | 06:45 PM
Toasted 2k Tranny
When I got the car it didnt run anything like my 91 se did
Now that I have finaly goten it back sence the tranny went out then after having the trany and such replaced it tosted another clutch in 8 days (the shope that serviced it incorrectly adjusted the clutch)
the car is runing better than my 91 did
it didnt drive this well when I took delivery of it
as for the name of the law it is the texas lemon law
Lakersallday24
Nov 7, 2024 07:31 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
TurboA32
Aug 27, 2015 08:44 AM
