"Service Engine Soon" = 0
Old Jul 23, 2002 | 04:37 PM
JodyBerry's Avatar
Alright - so I've read a lot of previous posts here and found good info on SES lights and their causes (thanks people). But I've had the light go on twice within a couple months and after having it checked (for free) at my local Autozone, it always came up with a 0 code! Has that happend to anyone before?? My car is a completely stock 2000 SE.
BTW, I had them reset it both times and it hasn't come back yet - at least for the past month.
Bill
Old Jul 23, 2002 | 04:55 PM
[maxi-overdose]'s Avatar
well...when it comes with electric sensor, it is really unpredictable. It might not be your car's problem, but just a loose ground can trigger the sensor. If you really want to dig into this, the best source will be the dealer. If your car is still under warranty, have them check it and insist them to fix it.
I would try to get rid off it ASAP.....b/c in case something really happen...it's going to be the same light too.
Old Jul 23, 2002 | 05:01 PM
swallac2
Maybe your gauge cluster is going bad??
Old Jul 23, 2002 | 07:24 PM
TimW's Avatar
The silent but deadly Moderator
this can be common with bad coils..
are you hearing any pinging under throttle? are you using prem gas?
Old Jul 23, 2002 | 07:53 PM
JodyBerry's Avatar
Re: this can be common with bad coils..
No pinging and I ALWAYS use premium. That's why it's such a mystery.
As an extreme case, could the OBD II tester they use possibly be bad? I've ruled out operator error since two different people used it.
Thanks,
Bill
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
