Brake Pad Installation
Old Jul 30, 2002 | 09:16 PM
KeVinMaxFan's Avatar
Can anyone point me in the direction of how to install brake pads on a 2k1 Max. My pads are coming up on replacement.
Any recommendations on brake pads from PepBoys/AutoZone etc.?
I assume it is pretty simple to swap out pads. Is it necessary to remove the caliper and push back the caliper piston with a c-clamp?
Any help is much appreciated.
Old Jul 30, 2002 | 09:50 PM
TimW's Avatar
The silent but deadly Moderator
please search..
and there are even writeups in the stickies at the top of this section.
There are some tricks for the rear, the info is there.
Old Jul 30, 2002 | 10:19 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
as far as a brand from an autoparts store, i would recommend bendix import quiet pads from advance auto part number mkd430IQ or performance friction pads from autozone. not sure what their part number is. both are a good upgrade from the stock pads without being rough on rotors.
Old Aug 7, 2002 | 09:24 PM
Searching
Will look around for those...thanks!
Old Aug 8, 2002 | 03:22 AM
mingo's Avatar
i recomend porterfield r4s and endless pads if they have an application for the maxima.
Old Aug 8, 2002 | 05:31 AM
doublea's Avatar
Re: Brake Pad Installation
Hey KeVinMaxFan, remember it is not just a matter of changing the pads, you have to clean-lubricate the caliper and the rails where the pads slide, for the piston it's only the front one that you will have to push with a c-clamp, for the one in the back you need to screw in the piston but clock wise, that is the only way the rear piston will go in. It's important that you verify the piston seal
just to be shure it is not damadge.
Good luck
AA
Old Aug 8, 2002 | 05:41 AM
RussMaxManiac
www.5thgenmaximas.com has a how-to.
Old Aug 20, 2002 | 05:31 AM
y2KAOSMax's Avatar
Re: Re: Brake Pad Installation
Good luck
AA
When you bleed the brakes, should the car be in park?? with the e-brake on or off??
Old Aug 20, 2002 | 05:52 AM
doublea's Avatar
Re: Re: Re: Brake Pad Installation
No but be shure the car doesn't move.
Cheers
AA
Old Aug 20, 2002 | 08:09 AM
y2KAOSMax's Avatar
Re: Re: Re: Re: Brake Pad Installation
Cheers
AA
So it should just be in park??
Old Aug 20, 2002 | 04:45 PM
doublea's Avatar
Re: Re: Re: Re: Re: Brake Pad Installation
Hey sorry for the confusion, if you have an auto then put it on park, but dont crank the e-brake if you are doin a brake job, with the e-brake on you wont be able to remove the rear pads from the caliper assembly thus from the rotor, so the answer is no e-brakes on when changing rear brake pads.
Cheers
AA
Old Aug 23, 2002 | 06:00 AM
y2KAOSMax's Avatar
Re: Re: Re: Re: Re: Re: Brake Pad Installation
Cheers
AA
Thanks for all your help. Brakes are finally done and feel great. Big inprovement over stock.
Old Aug 23, 2002 | 02:10 PM
doublea's Avatar
Re: Re: Re: Re: Re: Re: Re: Brake Pad Installation
No problems bro, you are welcome anytime.
Cheers
AA
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
